Bought a LG gpad x 8.0 online it got here and is asking for google info from last account and I don't know it and the people I bought it from will not respond and give me the info
SOURCE: i have been locked out
To unlock the pattern screen lock without signing in with your Google account You need to repair the software of the phone.
The steps to repair the phone are the following:
1. On the computer: Start PC Companion
SOURCE: my LG Android GT 540
Hard Reset LG Optimus GT540 100% working method
google_protectAndRun("render_ads.js::google_render_ad", google_handleError, google_render_ad);
You can use this technique to solve
= Remove Wrong trials in entering password
= account blocked and no access to menu
= to remove all your data from phone
= to remove viruses or malware application
= to speed up your device.
LG Optimus GT450 Hard reset is easy and can be done by anyone.
Follow this easy steps
1) Start your phone [phone must be started with or without sim]
2) Press volume up button + home button + search button
[Location of volume up button is on right side, location for home button is on bottom middle button of home screen and search button is right side of phone above camera button]
3) Keep all those button pressed at the same time for 5 second
4) Phone will ask you for " Are you sure you want to factory reset?"
5) Press yes and wait for 1 minute, Phone will hang first and than restart after sometime.
6) You've done resetting your GT540 successfully
Be careful, This trick will Erase / Format all your private data including contacts SMS and other things.
SOURCE: huawei m860 is locked screen
you should be able to attempt to unlock again after a set period of time. On my phone it is 30 seconds I have to wait after three failed unlock attempt. If that doesn't work then i would suggest going to the Huawei website and look at the FAQ.
SOURCE: My lg ms690 is locked and I forgot the pattern
I forgot my pattern and my google account info could u help unlock or find google account info
