SOURCE: Kyocera Ecosys FS-3900DN in HP emulation mode
Right click on the printer icon and choose properties. Your emulations are listed there.
SOURCE: how do i print envelopes on a kyocera ecosys FS-1300d
Just a suggestion but in the application you are using, make sure the "Page Setup" is set to the envelope you need and the source for the envelope is correct.
Also, check the driver settings to make sure they match what the application needs.
Don
SOURCE: Sir! the problem of our kyocera
Try cleaning the paper feed rollers for that cassette. Sometimes the rollers get dirty causing the paper to slip and not feed from the cassette causing the machine to register a paper jam.
The rollers can be cleaned with rubbing alcohol and a cloth.
SOURCE: KYOCERA ECOSYS FS-1118 ERROR-C-6400
reset the fuser code 6400 by pressing counter/system button, then go to service setting, then hold the start and hash button at the same time, now press enter and leave all buttons, press 163 and enter/execute, switch off and on, fuser will be reset, if not reset then replace fuser/fixing unit.
