Hi there, I am from the UK so model numbers vary but all basically the same. Do not fear it is simple really.
You need to take the door from it's hinges first. It will either have screws or bolts to the door or frame of the machine.
Now you have the door dismantled and in your hands.
place upside down and you will see screws ??? they will be situated around the door ?? the door comes in two parts and the glass is sandwiched between the two parts. ( Take photo if in need ) you will see see a metal shaft and spring where your handle will fit. All the best and Happy Christmas from the UK
SOURCE: Door catch plate Indesit d61
undo the screws at the top of the front door and puul the control unit out this gives you acsess to the door catch which is quite simple to replace be careful the stainless steel is quite sharpe
SOURCE: Replacing the door catch
If you're talking about a hook-like device that sticks out of the door and goes into a hole in the chassis of the microwave (or any other internal part of the door for that matter) you'll have to take the door apart. Brands and models vary, but some use screws which are obvious, and others use hidden hooks similar to the ones in the drawing I've added to this post. If you can post or e-mail photos of the area where the part goes, we may be able to translate our experience with other brands to yours.
SOURCE: Hotpoint CTD00 Door Catch Replacement
If yuo are referring to the catch on the door, then undo all the scews holding the 2 halves of the door together, and prize apart, fit new door catch.
If you mean the door lock, then you will have to remove the top cover and right hand side panel to access the door lock.
Hope this helps.
Plz rate this solution.
Thanks.
SOURCE: tumble dryer hotpoint ctd00
Unscrew all screws that hold the 2 halves of the door together, then with a screwdriver or similar, prize apart the 2 halves of the door, be careful the door glass does not fall onto the floor.
Fit new parts, reassemble door, and hey presto!!!
SOURCE: How do I remove the battery door from my ixus 75?
hi..
1. Turn your device off and remove the battery cover and battery
2. Remove the end-cover by pushing the cover away
3. Pull the bumper tabs up to separate the bumper from the device and remove bumpers
4. Snap new bumpers firmly into place
5. Re-attach the end-cover, re-insert the battery and re-attach battery cover..
thank u
rate me!!!
