SOURCE: Removal of Outer Bag for washing
Here is a link to my guide for cleaning the Kirby cloth bag... It should be helpful. :0) Marci
SOURCE: lack of suction even with filter removed.
I used to be a service manager for Electrolux. It sounds like possibly a clogged fan or hose. Take the hose off and check the amount of vacuum at the opening of the cleaner. If it has more suction without the hose, hold the hose in place backwards to try to **** the junk out of it. If the hose was damaged inside, it may be necessary to have it cleaned out with a very small hook. Make sure you have the filter & bag in place. They are needed to make a complete seal in the vacuum system. Make sure the suction control door on the hose (near the handle) if shut. This is normally only opened to vacuum curtains and loose hanging draperies.
SOURCE: kenmore vacuum model 37105 no suction
are the brushes moving?if so , it is clogged somewhere, that is my guess
SOURCE: poor suction (new bag, clean filter, clear hose)
check the impeller on the moter it may be missing a fin or two (question does it make any unusual noise or vibration ?)
SOURCE: Lost suction after I changed the bag and cleaned the air filter
The bag has a cardboard collar with latex. It must seal over the inlet. Make sure not to tear the bag when replacing.
Is the cover closing properly? The cover seals against a gasket. The same with the filter.
