Question about Nordic Track Exercise & Fitness
Nordic track t7.0 error beeps codes flashing light codes on control board
  • 80 Answers
GO to Nordic track website and look under support. It should direct you to what error codes mean.
Posted on Jan 02, 2019
6ya staff
SOURCE:
Anonymous
SOURCE: operating manual for cx1050 nordic track ellpitical
http://www.iconservice.com/pdf/NEL12940.pdf
I just downloaded a copy. It's 32 pages.
Posted on Feb 19, 2009
Anonymous
  • 64 Answers
SOURCE: Nordic Track Treadmill will not run
If console lights up but doesnt respond when buttons are pressed, you more than likely have a console problem. Key pad issue would be my best guess.
Posted on Jun 08, 2009
Tim F
  • 103 Answers
SOURCE: Calibration Mode for nordic track treadmill model
Hello there, The calibration mode for a nordictrack is as follows.
With the safety key out, hold the stop and speed up arrow at the same time while inserting the key. Release the buttons. You will then be in diagnostics.
You then press the stop button one time.
If you are trying to calibrate the incline you just need to hit the incline up button and the machine will do an incline calibration. The unit should go all the way to the top and return to the bottom when completed.
If you need to calibrate the speed you will need to press and hold the speed up button on the console until the display reads 85. The machine should then be running at its maximum speed (either 10 or 12 mph depending on the unit)
The display will show a speed on the console and should be within .3 of the maximum speed.
If it is not then it will need to be adjusted using a potentiometer on the control pwb.
To access the control pwb open the hood cover. Should be 3 screws in the rear of the cover and 2 screws on the bottom of the unit.
Once inside the cover locate the control pwb. On the control pwb there will be a yellow/orange potentiometer. This is the adjusting part.
Use a non-metallic phillips head screw driver to adjust the potentiometer either clockwise for faster or counterclockwise for slower.
Hope this helps!
Good Luck! Tim
Posted on Jan 13, 2010
Testimonial: "Although I haven't attempted this solution, but it makes perfect sense and will attempt it as soon as I get back to the treadmill - Thank you"
Therinnaiguy
Chandler Ede
  • 1420 Answers
SOURCE: 3 flashing light....Aire-Flo furnace AF80MPA100B5A
That control board is several hundred dollars. If I may make a suggestion, take a jumper and when the inducer fan starts, jump out the pressure switch. If it starts, it's not the board but a bad switch, hose or blocked exhaust vent.
Posted on Jan 15, 2010
fjrkcp
SOURCE: Belt slipping on Nordic Track c1900
My belt is slipping I tighten both alan head screws to the max roughly 7 turns and still have the broblem
Posted on Jul 10, 2010
Error code 660 & 595
Ray here, I had the same codes Icon couldn't ID them, new motor, then motor control board was troubleshot by me & my tech guy has never been the same, if it's a commercial grade unit, it starts wth a C, the motors have a lifetime warranty, so don't buy one, 9 out of 10 times it's the MCB ">
Oct 15, 2013 | Nordic Track Nordictrack C2050 Treadmill...
test the output control board motor, if there are NOT voltage for to input voltage terminal motor, the control board is faulty, replace.
2) If there are voltage terminal motor, the motor need to test, take out the belt, and try again if the motor RUN the problem is deck belt board, LubE IT. see my personal TIPS for motor.
What does the "code" 5E mean on the Audiostrider 990 Pro
Go to Nordic track and find out:
http://www.nordictrack.com/
Jan 20, 2013 | Nordic Track NordicTrack AudioStrider 990...
Nordic Track EXP 1000XI belt not working.
1) lube the deck belt,according the maintenance routing
2) lube the rollers bearing
3) measure the input voltage motor, if there are the motor need repair
4) measure the output voltage board, if there are NOT the board is faulty.see the block
God bless you
Jun 19, 2012 | Nordic Track Nordictrack Exp 1000...
My exp 1000 sudenly stops , the counters reset to 0 all the lights are on but the control pannel is nonresponsive an error code 07 showed up once. Any ideas?
I don't have any suggestions for fixing it but I wanted to give you a resource should you need to purchase a new motor control board, you can choose your specific model and browse parts list here. Hopefully you can get it to work though, depending on the model it looks like a replacement can run you $100-$200.
Feb 21, 2011 | Nordic Track Nordictrack Exp 1000...
I have a nordic Track EXP2000i that works for about a minute after it is plugged in but then the control console stops responding to buttons being pushed. The only buttons that beep are the 5 and 6...
hi,
check the other push buttons on the control console. if found faulty replace it. it is the only thing u can do in the control console. if problem remains u should replace the control console with a new one. for that u have to consult the manufacturer.
do one more thing before consulting manufacturers, remove the control console put out its circuit board. using a hair drayer heat the whole board. do not over heat.. then re fix it and test it.
ok
Dec 22, 2010 | Nordic Track Nordictrack Power Board...
I have a nordic track a2350,and the incline wont stay up.It beeps every 10 seconds and goes up then down .any tips
I've seen this problem several times, but many things can cause it. It's most likely the motor control board, but it could be a number of things. I'd have it looked at.
Oct 23, 2009 | Nordic Track NordicTrack Treadmill, A2550
I have a nordic track c2155. it powers up, but every button i push makes it beep. i have made sure the reed switch is 1/8th away from the pulley and that the unit has power
All, just figured something out. I had the evil beeping problem as well. I decided to play around and see if I could fix it. I unplugged the iFit adapter from the main control board and when I plugged it back in and tested it, IT WORKS AGAIN! NO MORE BEEPING!
Aug 19, 2009 | Nordic Track NordicTrack Treadmill, A2550
Exercise & Fitness Logo
104 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Treadmill Repairs...
Android Man
Android Man
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
