Wife cleaned the face plate, later when we added power, the only thing that works is the fan - will not turn off. None of the buttons work. Replaced the faceplate - still none of the buttons works.
SOURCE: Jenn Air Range SVD48600W (Circa 1998?)
Why are the oven indicator lights flashing?
Answer:
When power is first supplied to the appliance, a flashing time will appear on the display.
If a flashing time appears at any other time, a power failure has occurred. Press Cancel, and reset the clock if needed.
When the oven is not in use, the display shows the time of day.
If the indicator lights keep flashing after you have tried to reset the controls, then you may need to contact service person.
This is from the Jenn-Air website.
SOURCE: jenn air s136 stove won,t self clean
You've probably already read pages 34 through 37 of the owners manual for this oven. We had this stove in the house we bought and the owner wrote in his own directions, which seem to work fine:
1. Turn knob selector to clean.
2. Turn temp knob to clean.
3. Close and lock door.
4. Push enter button and turn dial clockwise to desired time.
5. Push enter button again.
You've probably already tried this, but just in case I figured I'd pass it along.
SOURCE: I have a jenn air oven and stove top. the
Just a suggestion, turn the breaker off to the range and leave off for 30 secs. This may reset the board. That's the easy way. If that doesn't help I'll try to find more on it.
SOURCE: Another one with Faceplate buttons not working?
The capacitors in these plates tend to burn out quickly for being so hot and lack of air cooling circulation. You can test all connection pins on the deck and faceplate with an ohmmeter in ohm setting to see which pins is not sending 25-30 ohms or 5 volts of power
