Reset to factory settings
If your screen is dim, touch the screen to wake up the watch.
Swipe down from the top of the screen and tap Settings . If you don't see Settings, you're using a different watch version. ...
Tap System.
Scroll down and tap Disconnect & reset.
When asked to confirm, tap Done .
SOURCE: change language
Here ya go:
What you will see
The printer display is not in the required language.
What to do
To change the language on the display back to the required language, do the following:
Steps
Action
Power the printer off and back on.
Press the down arrow button () four times.
Press the button once.
Press once.
5
Press once.
6
Press once.
7
Press the left arrow button () or right arrow button () until you see the desired language.
8
Press the return button ().
9
Press once to save the new setting.
To change the language on your HTC P3600, this is what to do.
Turn on your HTC Touch. Touch "Start" on your Home screen. Touch "Settings."
Touch System > Regional Settings. Select the proper region for the language you desire. Touch "OK" when prompted and "Exit."
Confirm your selection has taken effect by checking the language of any menu item from the Start screen. Your selections should be in the language you chose.
