The pipes coming out of the heater normally do not unscrew so that should not be what you are trying to unscrew. The connections to these pipes do unscrew and a 12" or larger wrench should be able to break the bond on the pipe threads and unscrew. Sometimes it helps to apply some WD-40 or any penetrating oil and then tap on the nuts with a hammer to help break up any corrosion or other bonding material that is holding the nuts.
Go to the manufacturer's website and enter your model number and click on "Support" and there should be a FAQ's, Owners Manual or other support options for you. Otherwise the website may have a "Contact" phone number to call or a way to Chat online.
SOURCE: Crystals Forming On Gas Hot Water Heater
You need a new anode rod in the water heatr. You will probably be looking at a new heater soon.
SOURCE: hot water problem
Someone has not sized the system correctly. The water heater will heat a certain GPM a certain temperature rise. Most of those "generalizations" from the manufacturers are referencing the lowest of all the flow requirements like 2 lavatories. The truth is, don't use other fixtures while showering or get a bigger system. Lots of information related to sizing the tankless system at http://www.mechanicalengineeronline.com/Mini_Sites/Tankless_Water_Heaters_Ebook/Tankless_Water_Heaters.htm Have a good one. PS:Properly sized On-Demand water heaters are actually really good. Be prepared for the day your water heater quits.
SOURCE: Carver cascade 2 No water at all comes out of the
Check the tank drain valve for water there.If you get a good water flow there you know the tank is getting water pressure.Check the first outlet downline from WH and if there is no water there you have a blockage or other problem.If you have to turn off water to tank, remove the outlet pipe ,and check for water flow from tank with in valve on.If no flow, tank is plugged up.
Hope this gets you going.
Testimonial: "Confirmed my diagnosis. Any idea how to get it unblocked?"
SOURCE: GE Profile Smart Water Heater leaking at top/no hot water
Leaking from the top as far as I can see looks like its around the relief valve.
If your electric hot water heater is not working...check out this tip about electric hot water heater problems
Electric Water Heater not Working
heatman101
