SOURCE: Intel Pentium Dual Core Vs AMD Athlon 64 X2
amd is better for online gaming and grafix, from my personal view they also can take more power,than a standard dual core intel proccessor so id advise you to go for Amd if its for online gaming
SOURCE: Intel Pentium Dual Core and AMD Athlon 64 X2 processors
I'd advise don't start thinking below E2180. As per the performance go, E2180 and AMD Athlon 64 X2 5000+ are almost same but E2180 runs cooler. If you are going to use dedicated graphics card, go for E2180 and if you want a CPU for Integrated Graphics go for AMD Athlon 64 X2 5000+ because most of the 780G/790X chip-based AMD-compatible boards offer superior IGP.
Best wishes...
SOURCE: Memory
After looking at the manual, it does appear that the_fire may be correct. Your on-board video has a max shared memory of 512MB. If it is set the max, that is exactly why you only show 2.5GB.
This is from your manual:
Graphics Radeon HD 3300
Onboard side port memory 64MB (TA790GX A2+)
Onboard side port memory 128MB (TA790GX 128M)
Max Shared Video Memory is 512MB
SOURCE: i changed my processor from an amd athlon 64 3800+
Change the CPU back, upgrade the BIOS, and try again.
SOURCE: i am installed windows 7 64 bit os in my system.
Download the drivers from Asus. http://support.asus.com
Also make sure in your Bios your HD audio is not set to front panel.
