SOURCE: leaking water from front door after cycle is done
If your washer is upstairs it's probably the washer drainpipe or the piping in the walls. Go look.
SOURCE: Whirlpool Front Loading Door leaking water
The most common cause for a front loading washer to leak from the front door is a torn or detached gasket where that gasket attached to the machine.
Open the door and begin to pull the gasket away from the opening. Look for any problems. If you find a place where the gasket is not firmly secured to the opening, you can list that area up and glue (even with super glue) the gasket back down to the metal opening.
If you find gasket damage, it will need to be replaced.
SOURCE: water leaking bottom front door
Check out the front seal carefully for a replacement. Due to the flexibility of the seal, it is not to easy to spot a tear mark, Under pressure of an operation load, a small tear will allow water leaking through, so there is a leak. It is very common that a hard sharp object left inside clothing and during washing cycle, it makes its way to the seal and cause a damage. Hope this can help.
