The thread spool is bigger than normal thread spools I have a Bernina Activa 140
There is no difference to loading the bobbin spool. If you are talking about the thickness being a problem you will have to lower the tension of the bobbin. That is easily done by turning the screw on your bobbin case in a counter clockwise motion until the thread feeds with a tension similar to level four on the top tension.
Testimonial: "Hi Jimmie, thanks for this, but the spool pin is to small/short for the big spool on which the upholstery thread is on. I need to get it off onto bobbins - is there any other accessory I can use?"
SOURCE: can't pull thread from spool
The sequence of setting up of thread from spool to needle is not complied to actual setting is one factor to be consider it affect the sequence timing of sewing.Particularly some machine are common in starting up threading.fig. shown a basic flow of thread on red color.It maybe a helpful one
In addition to this the set up of thread to bobbins winder is also need in right place the thread should be in clockwise rotation when coming out to bobbins casing as shown in fig.
as you can see when thread was pulled out from bobbins winder is moving counter clockwise.If you try to sew, try cotton fabric and set dial to # 3 to 4 and stitch set range to 8 up to 12 depend on layers and thickness,After setting try to sew manually ,turn hand wheel by your hand first,let upper tension catch the lower bobbins tension and arranged thread and insert fabric use hand turning hand wheel several time until stich appear on fabric observed loop thread on lower bobbins on fabric.if accumulation of loop thread on lower adjust upper tension also dial tension gradually until it has a smooth stich appear.
SOURCE: thread knotting around bobbin case
hello, I had the exact same problem and could not find the solution until i took my machine to my sewing sensei and i solved my tedious problem. It was actually not a tension problem at all but a threading problem. Make sure you have threaded your bobbin correctly and that when you pull on the bobbin thread that the bobbin turns the right way. (mine must spin anti clockwise to work) Make sure that when you pull up the bobbin thread using the needle that it is not over the feed dogs connective bar but under it. A big problem when the thread gets caught around the bobbin case wheel is that the thread is looped around the feed dogs once and that causes the thread to get caught around the bobbin wheel. In conclusion, thread the bobbin correctly and read over your instruction book before spending the money to get it fixe in s shop.
SOURCE: Singer 457 Zig Zag Sewing Machine not catching bobbin thread.
There are manuals avilable online to purchase for the singer machines, SOrry I was not able to locate a site that has them for free.
.... http://sewingonline.co.uk/singer-manuals.html
SOURCE: why does the shuttle hook grab the spool thread
The shuttle hook is suppose to hook the needle (spool) thread and loops it around the bobbin case to form the lock stitch. Is it possible that something was adjusted without proper clearances as to allow the thread looping around the bobbin case to do so without catching up where it should pass through freely?
~<Ray>~
SOURCE: I am experiencing tension issues.
Good day!
please try this simple tips:
Good day!
A sewing machine operator can often help themselves when their machine does not operate properly.
Here are some simple instructions, which if properly used can save time and mechanics service calls.
TROUBLE;UPPER THREAD KEEPS BREAKING;
This could be trouble;================Do this;
1.Top tension to tight================loosen tension 1 turn
2.Machine improperly threaded=========check threading
3.Thread twisted on guide post========"
4.Thread twisted out of tension======="
5.Take up spring bent or broken=======Check action of spring
6.Thread jumped off pull off finger===Check threading
7.Needle bent or burred===============new needle
8.Bad cone of thread==================try another cone
TROUBLE;LOWER THREAD KEEPS BREAKING;
1.Bobbin tensionspring to tight=======Loosen tension slightly
2.Bobbin threaded wrong===============check threading
3.Bobbin wound to tight or uneven=====try new bobbin
4.lint or thread on bobbin case=======clean inside case
5.Lint or thread inside hook==========clean inside hook
6.Bobbin case nicked bent or burred===check/change case
TROUBLE;MACHINE STARTED SKIPPING STITCHES;
1.Needle bent or burred===============change
2.Needle set in crooked===============Check
3.Thread jumped off take up spring====check threading
4.Thread jumped off pull off finger===check threading
TROUBLE STITCHES SHOWING LOOPS;
1.Forming loops on top of cloth=======Tighten bobbin tension
======================================or loosen top tension.
2.forming loops on bottom of cloth====Tighten top tension
3.Bobbin placed in case incorrectly===remove and replace
4.Bobbin thread slipped from under====check threading of
tension===============================bobbin case
5.Lint or thread in top tension=======clean between tension discs
Thank you and good luck.
