Ramesh Reddy Ramesh Posted on Dec 15, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Konica Minolta pagepro 1590 MF drum error - Konica Minolta Office Equipment & Supplies
Norman Weimar
Level 3:
  • Konica Minolta Master 7,035 Answers
  • Posted on Apr 27, 2019
Norman Weimar
Level 3:
Answers
7035
Questions
Helped
1913049
Points
11959
5 Related Answers
Anonymous
  • 214 Answers
  • Posted on Jul 02, 2008
SOURCE: konica minolta pagepro 1350w error light won't stop flashing
pleas install status monitor, it will tell you what is wrong
Anonymous
  • 3 Answers
  • Posted on Apr 16, 2009
SOURCE: konica minolta 1350w status display comes on at start up
Open c:\windows\system32
find a file called MSTMON_Q.EXE
right click and rename the file to anything with a file extension .exe, I named it MSTMON.EXE
Create a shortcut to this new file in case you need it in the future and put the shortcut on your desktop
also, write the original name of the file down or put it on notepad, in case you want to change it back.
restart windows
Anonymous
  • 210 Answers
  • Posted on Jul 09, 2009
SOURCE: konica minolta pagepro 1400w paper jam
have you tear the paper when removing? there is a small paper left still inside the paper path. open the back side and the top part and check for small paper. I hope that will solve your problem and if think the problem still there the problem is one of the paper sensor actuator is broken or out of place.
freetek
Steve Allison
  • 5569 Answers
  • Posted on Oct 10, 2009
SOURCE: konica minolta pagepro 1350w fatal print spooler
A 'print spooler' is a range of memory either internal to the printer (sometimes called 'buffer memory') or set aside from the RAM in your system. A fatal error normally means the material you tried to print has been lost and must be sent to the printer again. If the error continues to show up, you may have bad printer memory or perhaps the driver software in your system has gotten stepped on by the operating system and needs to be reinstalled. Windows loves trashing files to keep life exciting.
This problem is not related to the drum or toner cartridge.
Anonymous
  • 35 Answers
  • Posted on Feb 16, 2010
SOURCE: Konica Minolta Pagepro 1350 page count or Print Config sheet?
please go printer utilty option on your pc then you can print a testpage
Konica Minolta Pagepro 1590 MF Multi function Printer. It has print drum error and front cover open and slide the blue tab across the drum unit several times on message display. Please solve problem.
The error message "print drum error and front cover open" on a Konica Minolta Pagepro 1590 MF multifunction printer typically indicates that there is a problem with the print drum unit, and that the front cover of the printer is not properly closed. Here are a few steps you can try to resolve the issue:
  1. Close the front cover: Make sure that the front cover of the printer is properly closed and latched shut. This will help to ensure that the print drum unit is properly seated and can function properly.
  2. Check the print drum unit: Remove the print drum unit from the printer and carefully inspect it for any visible damage, such as scratches or cracks. Make sure that the drum is not damaged, and also make sure that it is not dirty. if it is dirty clean the drum with a dry and soft cloth.
  3. Slide the blue tab: Make sure that the blue tab on the print drum unit is in the correct position. The tab should be sliding easily back and forth across the drum unit and the drum unit should be locked in place.
  4. Reinstall the print drum unit: If the print drum unit is not damaged and the blue tab is in the correct position, then re-install the unit into the printer.
  5. Reset the printer: Once the print drum unit is reinstalled, try resetting the printer by turning it off and unplugging it for a few minutes before plugging it back in and turning it on again.
If you have done all these steps and the problem persist, it's possible that the print drum unit itself is faulty and will need to be replaced. If that's the case, it's best to contact a service technician or the manufacturer for help in replacing the unit.
Please note, it's always recommended to refer to the user manual of the printer or consult with an authorized technician before taking any steps, this will help you to avoid any possible damage to the printer or any other parts.
3answers
Pagepro 1590 lowtoner error
The obvious question is: Are you out of toner? How long ago did you replace the cartridge and how many PRINTS (aprox.) did you get from your new cartridge?
ALSO, is your 'original' toner from Konica/Minolta or some other 'off-brand' mfg?
See the LINK below and try a TOTAL RESET first.
SOMETIMES during shipping toner can be dumped or compressed to one end of your cartridge and the sensor may think you are out of toner... when actually have plenty... it's just not available evenly!
So do this... CAREFULLY. Remove the toner cartridge and take it OUTDOORS! Put down a sheet of newspaper and GENTLY tap a long flat edge of the cartridge keeping it as horizontal as possible! The object is to get the toner EVEN across the entire cartridge bottom ~ or silver roller inside...
THIS CAN BE MESSY if you are too rough! IF you get ANY toner on your hands or clothes use COLD WATER and dish soap to wash it away... of course do NOT wear anything white ~ other than your boxers.
Now slightly wet a paper towel and wipe the toner case before you reinstall it. REMEMBER that any loose toner on the cartridge or within your printer WILL get blown around by your fan and then onto your optics (lenses) causing spots on all of your prints!
I DO NOT recommend that you dust toner cavity (were the toner mounts) BECAUSE you will have almost DIRECT ACCESS to your very sensitive PRINT DRUM... ONE SCRATCH on it will be transposed to ALL of your future prints until you replace the drum... NO fun.
Anthony
Complete RESET or REBOOT of Konica Minolta pagepro 1590 MF
Konica minolta pagepro 1390 mf printer problems
what is the problem sir/mam?
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
How we reset printer konica minolta 1390
About 88,000 results (0.73 seconds) Search Results
    [PDF]PagePro1380/1390 MF Service Manual - Printers - Konica ...
    printer.konicaminolta.net/drivers/other/1390/1380_90_fs.pdf
    the risk of damage to the product, KONICA MINOLTA BUSINESS TECHNOLOGIES, INC. (hereafter called the KMBT) strongly recommends that all servicing be ...Missing: we
    [PDF]PagePro 1390 MF Printer / Copier / Scanner User's Guide
    images10.newegg.com/User-Manual/User_Manual_28-117-006.pdf
    PagePro is a trademark or registered trademark of KONICA MINOLTA. PRINTING .... Print Media 20. What Sizes of Media Can I Use? 20 .... Stop/Reset key. Exits the menu. ... Right-click the KONICA MINOLTA PagePro 1390 MF printer icon.
    [PDF]Technical Guide - Printers - Konica Minolta
I have a SCANNER ERROR lamp error message on my Konica Minolta 1380mf page pro pinter, do you know how I can fix it please?
You have a bad drum unit, you will need to replace your drum (dr310) along with the developer (dr310) it's not all that difficult but requires several step to reset the error code, clear the counters and calibrate.
3helpful
I have a minolta PagePro MF 1380 it notice on LCD SYSTEM HALT what must i do
you need to replace the main borad, this error means that is a problem to comminicate with video board, so you have to replace your board to get your printer working fine. thanks.
1helpful
Where can i find the driver of this printer page pro 1380 MF
try www.konica-minolta.us then "printers",then "pagepro", then "pagepro1380MF", then "software&driver". That should do the trick.
Konika minolta pagepro 1380 printer
try out the vista driver>it may be functional for win7
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
