SOURCE: screen went black
If when you try powering up the phones and the keypad just lits up then it is the flexcable that needs to be replaced.
or the LCD
SOURCE: I dropped my phone and the screen went black. My
You have damaged the delicate internal LCD beneath the more rigid touch panel......but luckily for you, it is easy to replace and rather inexpensive. Here is an example of what you need....OEM replacement with return policy.
Cut and Dry you cant mess this up, trust me......just use your head and you will feel like a real tech genius when your done. now you will be good to go and try not to drop your phone so much...:D
Good Luck and Please Rate This Post
SOURCE: i dropped my samsung e840 phone in the bath
Recent phones dont agree with water to much, but what you can do is pull it apart and spray it all with a electric cleaner, but if you have insurance on your phone that would be the best way to replace it, warranty wont cover it. you could try to hard reset it but most likely wont work still
SOURCE: My motorola rival's screen went black two days ago
i smashed mine on the wall after reading this and it worked! no dimming problems either! thank you!
SOURCE: I dropped my Samsung Galaxy
In maost cases,the screen is replaceble.Check it from a local electronis store or you can try on eBay
