Sewing Machines Logo
D
David Cherbonnier Posted on Dec 13, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How can I open the top cover of the kenmore model 158.17741 to oil the mechanisms. The manual shows a picture of it open but no instructions on how it got that way
Jimmie Sill
Level 3:
  • Kenmore Master 706 Answers
  • Posted on Dec 15, 2018
Jimmie Sill
Kenmore Master
Level 3:
Answers
706
Questions
18
Helped
126482
Points
2291
There is between two and four screws on top of the machine. Remove them. Pay attention to the bobbin winder. You may need to move it in order to get the plate to be released.
I am trying to oil my white model 1405 machine I can't open the top to do it
You can download a manual for your machine:
Instruction Manuals
You probably need to open the left cover first, then look for a latch or something to release the top.
How do I oil 8 stitch Kenmore sewing machine
Not sure what an "8 stitch" sewing machine is. Model #?
If it's a mechanical machine, the following may be helpful:
Wheel on right side that controls the needle up and down is very tight...
Should I oil the motor on a kenmore sewing machine model 158.905?
Do NOT oil the motor unless the manual instructs you to do so. (Sears carries manuals for most of their machines.)
Your machine appears to be an older mechanical machine. As such, oiling would be necessary for the moving metal parts. The following may be helpful to keep your mechanical machine happily operating. (Although the following is for machines that have seized due to lack of oil, following the procedure is helpful in preventing the machine from seizing.)
Kenmore sewing machine model 158.12260 Manuel
Sears carries many manuals for Kenmore. That's probably the best place to check--unfortunately, they generally are not free.
The sewing machine could probably use a good cleaning and oiling. These old (but great!) mechanicals need 1-2 drops of fresh, good quality sewing machine oil (Tri-Flow Synthetic Oil works great!) every place that metal rubs against metal. NO oil on plastic, nylon, rubber, or belts!!! Simply open the machine's top, left side, and free arm cover (if not a free arm, you'll need to access the underneath of the machine). Gently hand rotate the handwheel toward you and apply a couple drops every place metal rubs metal. Don't forget the lever & dial mechanisms too. Probably, in your case, the bobbin winder mechanism (do NOT oil the rubber tire!). Then you can apply hot air from a handheld hairdryer into the mechanism to help free it up.
Stuck reverse button on kenmore 158.17011
I believe your Kenmore is an older mechanical machine. If so, how long has it been since you've given it a good cleaning and oiling? Mechanical machines need frequent TLC, otherwise the old oil turns into a glue-like substance and starts sticking things together, including your selector levers and dials. Give your machine's bobbin area a good cleaning with a soft brush to remove dust and lint.
Then, use ONLY fresh good quality sewing machine oil. Open the case top and free arm cover (if it has one--if it is a flat bed, tilt the machine back so you can access the moving parts under the sewing surface), gently handrotate the handwheel toward you, watch where metal rubs metal and apply 1-2 drops of oil. (Your owner's manual may have instructions for oiling and your machine may also have oil ports--little holes-- where oil should be applied.) Do not skip the feed dog moving parts. Also, there is usually an oil port behind the bobbin mechanism next to the case. Put a single drop of oil on the bobbin race. Do NOT oil plastic, rubber, or belts! Be sure to move the selector levers and dials and, if possible, apply a couple of drops to their moving parts as well. To help loosen things quicker, direct hot air from a handheld hairdryer into the internal mechanics of the machine. Repeat the oil/heat process until things are moving freely.
In the future, be sure to give your machine a thorough cleaning and oiling after about 40 hours of sewing use. A drop of oil on the bobbin race is good every 8 hours. If your machine sets unused, oil every six months to keep it operating.
I'm trying to oil my machine, but don't know how to get the face cover off??
Perhaps the Owner's Manual will help:
http://homeappliance.manualsonline.com/manuals/mfg/kenmore/38515358.html?p=1
Be sure to use good quality sewing machine oil and white grease as explained in the manual.
P.S.--from the manual's instructions, it appears that you do not need to remove the face plate to oil your machine.
1helpful
Do I need to oil my Janome 525S sewing machine?
if you have a instruction manual look in it for oiling instructions and if you don't have a manual or it doesn't say anything about oiling,, then go to the website of janome and contact their customer service and ask them if you can oil the machine.. some machine can be oiled and some can not..
My Kenmore 12493 is making a loud squeaking noise. I have oiled the machine as per the manuals instructions...I can not figure out where the squeaking is coming from.
Hi
If you are good with machines you need to take off the bottom cover and oil all of the drive. The motor may all so need to be oiled.
Good luck
6helpful
Where to oil a Kenmore 158-17600
Remove the top and bottom covers. Turn the wheel and put a drop of oil anyplace that moves and rubs.Also at the ends of each shaft. Open the side cover and oil the needle bar and all the parts inside that move and rub.Put a drop of oil on the hook.Do not put a good piece of fabric in the machine right after you've oiled it. Sew it off on some scraps that you can throw away.
sewman7
Oiling sewing machine
Sorry couldn't find a free manual - check here though, they are only $10; http://www.sewusa.com/Sewing_Machine_Manuals/kenmore_Sewing_Machines_385.htm although they dont have the exact manual for your model, the oiling instructions should be the same for all the 385 models. it is a good site - you can contact them direct for more info and you might get lucky; http://www.sewusa.com/index.htm These guys are also worth a try; http://www.sew4less.com/manuals.php They claim to offer a manual for your exact model, but the picture shows a generic manual which they say will offer the same info Hope this helps, good luck, please post again if you need more help :)
Top Kenmore Sewing Machines Experts
ZJ Limited
ZJ Limited
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
