Watches Logo
A
Aleks Posted on Dec 12, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Breitling galactic unitime losing time
Brand new purchase, noticed it looses time (8-10 seconds every 24 hours)
deton8 von Splosion
Level 3:
  • Breitling Master 3,342 Answers
  • Posted on Dec 13, 2018
deton8 von Splosion
Breitling Master
Level 3:
Answers
3342
Questions
6
Helped
927041
Points
54123
Hello Aleks,
My personal opinion:
Take it back (undo your "new" purchase).
Real watch movements DO NOT have the accuracy
of "QUARTZ" watches...!!
If you have a WARRANTEE that allows for higher
expectations... I would say TAKE IT back
immediately..!!
Worse than dropping a few SECONDS from your
watch...you are wasting time from your LIFE tribulating over nonsense
Breitling Caliber B35 (automatic) specs: watchbase.com/breitling/caliber/b35
Movement: Automatic
Display: Analog
Diameter: 36.60
Jewels: 41
Frequency: 28800
Date: Date
Hands: Hours, Minutes, Seconds, World Time
Additionals: Chronometer
Description
The Breitling caliber B35 is a new movement that was launched at BaselWorld 2015. It is an in-house (manufacture) movement with worldtime functions; it is also the first in-house Breitling movement not to feature a chronograph. It measures 36.6mm across at a height of 7.8mm.
If you purchased your UNITIME for accuracy
you skipped over some VASTLY SUPERIOR
quartz watches that would better suit your
EXPECTATIONS... ( for $$$ thousands less ).
Breitling Caliber B35 is a very nice movement...
(I think you need a QUARTZ... digital)...
ALL in my opinion!
https://en.wikipedia.org/wiki/Carnac_the_Magnificent
4 Related Answers
escapement
Arturs Kalnins
  • 2338 Answers
  • Posted on Dec 18, 2008
SOURCE: Breitling watch move fast
No matter what is your watch movement (quartz or mechanical) it can be adjusted to keep time properly.
Bring it to your nearest watchmaker and the problem will be solved.
9 sec a day is far too much for Breitling.
Anonymous
  • 24 Answers
  • Posted on Sep 19, 2009
SOURCE: breitling watch winder rotations requirments
The watch should last 36 hours from fully wound. If your wearing the watch and using a watch winder and its still stopping, you have a problem with the mechanism. Get it serviced. (its probably just a clean and oil req'd)
Anonymous
  • Posted on Aug 11, 2010
SOURCE: Watch has started
We had the same issue. Replaced new batteries etc. Since it was an expensive Invicta watch and less than a year old we assumed it was perfect. However, you need to take it into a upper end service center and have it "serviced" they will oil, align, etc and it will probably solve your issues.
escapement
Arturs Kalnins
  • 2338 Answers
  • Posted on Feb 27, 2011
SOURCE: Is there an easy way to change the date on my
Of course, there is the way to do that. Try to pull out crown carefully and you will notice that there are two positions (clicks). Second click is when the crown is fully pulled out and the watch hands move by turning crown. But there is first click (lets say - crown is pulled just half way out). In this position the date/day can be quickly changed by turning the crown. Crown=winder.
How do you know if a watch battery is fading. On some watches the second finger moves two seconds at a time but on one of my watches it is just losing time.
If it looses time and it has been like more than 2 or 3 yrs since replacing the battery it could be that the battery is loosing power. loosing time is a symptom of a fading battery power.
1helpful
Can anybody tell me if this is a genuine breitling as I am looking at purchasing it. Thanks
I don't know much about watches, but that's a Real Genuine Breitling watch. It is very nice and luxurious .
Feb 18, 2013 • Watches
Is my Brietling watch fake or real #A25082
if your breitling watch had been purchased to its authorized retailer, there is nothing to worry about but if your watch is had been purchased to anywhere else it is probably fake.. but you can bring it to watch expert or in authorized retailer of breitling brand of watch and you can ask for its authenticity because they have to see it on actual so that they can determine it that if it is fake or not. because there is so many fake watch that has the same looks outside of the original watch but bot on the iside. i hope i had been helped you.
4helpful
Is there an easy way to change the date on my breitling crosswinds watch without manually rolling the crown through 24 hours every day?
1helpful
The 24hr hand is meant to keep time in another
I too was confused at first at setting the second hand after reading the directions. I read your post in searching for a solution, then I figured it out. Check the watch face, the second hand is operating using military time. (24 hr. time) You will see 24 hour time embedded on the face.
For example: if you wanted to set both hands to be at the same time to test this. At say 10 p.m. set the second time hand to 22 for 2200 hrs. (10 p.m.) Let's say you woke up at 7 a.m. The second hand would be at 0700 (Embedded on watch face) then at noon it would say 1200 on the watch face... I now use the normal hands for local time and set the 24 hour hand for my home time.
I hope this helps.
Breitling watch winder rotations requirments
2answers
Breitling navitimer watch
breitling navitimer, keeps perfect time on the desk, but when ion the wrist it runs fast, as much as one hour in 24 hrs
Top Breitling Watches Experts
vince
john h
ADMIN Andrew
ADMIN Andrew
Are you a Breitling Watch Expert? Answer questions, earn points and help others
