Behringer Pmp3000 16 Channel Audio Mixer Logo
E
Evelyn Posted on Dec 11, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need the manual for dmxp6 mixer AD108413 - Behringer Pmp3000 16 Channel Audio Mixer
Terry
Level 3:
  • Behringer Master 11,377 Answers
  • Posted on Dec 12, 2018
Terry
Behringer Master
Level 3:
Answers
11377
Questions
Helped
4625782
Points
152765
Your question appears in the Food Mixers category, which appears to be a mistake using the word mixer..
I searched the internet using Google.com and only found the dmxp6 mixer for sale, but not a manual.
You might try contacting the manufacturer of technical pro mixers.
https://www.tpro.com/pages/technical-support
Allen & Heath XONE:42 Professional Four Channel DJ Mixer. How to repair a blown left channel blown?
If one of the channels on your Allen & Heath XONE:42 mixer is not functioning properly, it is likely due to a problem with the channel's internal components or electronics. To repair a blown left channel, you will need to disassemble the mixer and locate the source of the problem.
Here are the general steps you can follow to troubleshoot and repair a blown channel on your Allen & Heath XONE:42 mixer:
Disconnect the mixer from any power sources and remove any cables or accessories that are connected to it.
Carefully disassemble the mixer, following the instructions in the user manual or a service manual if available.
Once you have access to the internal components of the mixer, carefully inspect the left channel for any visible damage or problems.
If you find any damaged or faulty components, you will need to replace them. You may be able to find replacement parts online or through a specialist DJ equipment retailer.
If you are not comfortable with disassembling and repairing the mixer yourself, you may want to consider taking it to a professional repair service. A technician will be able to diagnose the problem and repair the mixer for you.
Keep in mind that repairing electronic equipment can be complex and requires specialized knowledge and tools. If you are not familiar with electronics repair, it is recommended to seek the assistance of a professional.
2answers
Can I connect only one speaker to a yamaha emx 312 sc power mixer?
First it is certain that you would not want to plug both outputs of the stereo power amp into one speaker combining both channels into the same speaker. (see image from manual below - also link to manual)
Next I would be very concerned about only using the one side of the main amp out as it could cause an unbalanced load, or you could be driving the load into dead air connection and any of these conditions are destined to cause premature failure of the power amp.
Taking a quick scan of the manual for this unit, it appears what is pretty common to most powered mixers, hook up two matched speakers/loads to each chanel of the output.
Your best bet is to shed those monster cabs, there really is no need for them especially with this sized powered mixer, and get yourself a nice pair of full range cabs like EV1202;s, EV SX300's, or some nice 2 or 3 way 15" JBL's/
Just my opinon.
Link to Yamaha EMX 312 Owner's Manual:
Yamaha EMX Series Owners Manual
Manuals mixer
For what make and model mixer?
May 01, 2013 • Music
1helpful
How do i plug in 2 passive speakers without having speakon cables to insert into the back?
The mixer uses unbalanced TS connectors You need these connectors to hook up the speakers. Below is a link to the manual for the mixer.
link:
2helpful
I NEED A SERVICE MANUAL FX 24 MIXER PEAVEY
I believe the manual you are looking for can be found here: http://www.manualnguide.com/manual-get/4220/
How do i connect dis mixer to another mixer?
First of all a link to the manual:http://s3.amazonaws.com/samsontech/related_docs/XM910_ownman_v1.pdf Have a look at page 14, 9. Go out of MixOut ( line level ) into any line level auxiliary inputs left and right on the other mixer. You didn't say what the other mixer is so this is the easiest. What you will have is a sub mix of everything plugged into the Samson controllable by the controls for the line in you are using on your second mixer. There are other options which you should be able to discover by reading your manual for the Samson and the manual for the other mixer.
1helpful
2answers
I need an owner manualfor a Behringer pmp 3000 16 channel mixer
You can download the manual by clicking this link
You'll require Adobe PDF Reader installed on your PC to view this manual. If it is not already installed on your PC, download it free from:
http://get.adobe.com/reader/
Hope this solves your problem. Thanks for using FixYa
Top Behringer Music Experts
john h
Are you a Behringer Music Expert? Answer questions, earn points and help others
