Sewing Machines Logo
Betty Patton Posted on Dec 11, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Where to find serial number on a viking designer SE sewing machine?
Douglas Plant
Level 2:
Champion:
  • Expert 222 Answers
  • Posted on Jan 08, 2019
Douglas Plant
Expert
Level 2:
Champion:
Answers
222
Questions
Helped
64087
Points
402
It is on the bottom of the machine
3 Related Answers
Anonymous
  • 110 Answers
  • Posted on Dec 18, 2007
SOURCE: embroidery stick
You need the USB Manager software to view the files. Have a look at all the software that were supplied with the machine. Load the embroidery software on your laptop and then open the USB manager.
When it opens it will show a light blue screen and grey icons to the left. Click in "disk", then click on "read disk" and you should be able to see your designs. The grey icons will turn orange were designs are stored, and the grey ones indicate empty space for more designs.
Enjoy your fantastic machine
Debbi's Sewing Machine Repair
  • 7365 Answers
  • Posted on Nov 13, 2012
SOURCE: I need a new LCD screen for my SE designer Viking sewing machine.HELP
you would have to check with husqvarna or a dealer
99rannellis
R.A. Ellis
  • 12731 Answers
  • Posted on Jan 26, 2016
SOURCE: Need a service manual for a viking designer SE sewing machine
Service manuals are very difficult to find as manufacturers really don't want users to be have that information. However, if you search the internet, you may find some service manuals that are available from service repairmen or a parts diagram may also be helpful.
Husqvarna Viking Designer Diamond Deluxe sewing and embroidery machine. Code for service mode on Designer Diamond Deluxe?
Question edited for a lot more clarity.
Question moved from Watches to Husqvarna Viking.
https://www.manualslib.com/manual/1054795/Husqvarna-Viking-Designer-I.html?page=6
Also found this
Follow the instructions in the Installation Wizard. When asked to enter your Installation Code, enter the following number: 9200.
and all this
I am needing a service code password for my Husqvarna
JustAnswer https://www.justanswer.com > small-appliance > ciwzd...
Jun 18, 2019 - I am needing a service code password for my Husqvarna. I am needing a service code password ***** my Husqvarna Designer Diamond sewing machine.
1 answer · Top answer: Just go to the tools screen and look at the timer which will give you the hours and minutes ...
SOLVED: Service Menu For Husqvarna Designer SE
Fixya https://www.fixya.com > ... > Husqvarna > Designer I
Hi SewTechWayne, do you happen to have the latest pass code? 5031 is no longer working on my machine. Thanks!
User's Guide
Husqvarna VIKING https://www.husqvarnaviking.com > ClientSite
When asked to enter your Installation Code, enter the following number: 9200. 5. In the 5D™ Configure Wizard under MyMachines select your machine type: ...
140 pages
Husqvarna Viking Designer I Service Manual [Page 6]
ManualsLib https://www.manualslib.com > ... > Service manual
Husqvarna Viking Designer I Manual Online: Service Program. ... Press Handling Get into the service program of the machine by pressing the reverse feed...
2answers
I have an Viking Designer SE Sewing/Embriodery machine and I just starting exploring Embroidery? My thumb drive won't show the designs on the Embroidery machine, but they are on the USB thumb drive.
Most newer USB drives are not compatible with the Designer SE. Only Husqvarna Embroidery USB Sticks are guaranteed to work with this sewing machine. https://www.manualslib.com/manual/827718/Husqvarna-Viking-Designer-Se.html?page=21 . The entire manual is available from https://www.husqvarnaviking.com/support/DESIGNER-SE . One tip: try making sure that the file is not inside a folder on the USB stick. (In File Explorer, you should open the drive and see the file in that first list/window. If you build the folders on the sewing machine, it's less likely to be a problem.)
Other USB sticks can sometimes work. However, you need to format the stick at the sewing machine before putting files on the USB stick at the computer. 2GB and larger USB sticks are the most likely to give problems. 32MB to 1GB sticks are more likely to work. Only one person found an 8GB USB stick would work with the Designer SE. Most new USB sticks are formatted with a NTFS format. The sewing machine may be looking for a FAT16 or FAT32 format. The other possibility is limited USB drivers on the sewing machine. (I've got an Ag GPS position system that won't accept any USB stick unless it is labeled as "Works with Windows 98". Those USB sticks didn't need the OS to download a driver from Windows Update when they were first plugged into the computer.)
I hope this helps.
(The Designer SE could talk directly to Windows XP or Vista via USB. However, the programming probably had more in common with Windows 98.)
2answers
Can the embroidery arm of a Designer 1 Viking sewing machine be repaired?
It depends what needs repairing? They are available to buy
viking embroidery arm ' eBay
https://www.ebay.ca > sch
21 items - Husqvarna Viking Embroidery Unit/Arm Attachment Model VSMAB ForDesigner 1 Sweden · Husqvarna Viking Designer 1 Embroidery Arm, W/ Hard And ...
husqvarna embroidery unit ' eBay
20 items - Husqvarna embroidery unit for #1+. Embroidery unit in case,. Brand New. C $400.00. Buy It Now. Husqvarna Viking Designer SE Embroidery Arm Unit ...
Or ask Husqvarna Viking to repair or replace under warranty
Machines - HUSQVARNA VIKING®
https://www.husqvarnaviking.com > Machines
The EPIC™ ' 980Q sewing machine is our most advanced and comprehensive computerized sewing machine ever. Made for Sewers, by Sewers™ to set your ... ‎Sewing · ‎Quilting · ‎Designer epic™ 2 · ‎Designer sapphire™ 85
2answers
My Husqvarna designer SE is not telling me bobbin is empty
Hello, Dene -
Go to this Husqvarna Viking Desinger SE Troubleshooting website:
http://www.husqvarnaviking.com/SiteMedia/Products/Machines/Support/Designer_SE_Troubleshooting_EN.pdf
Scroll down Page 1 to the section with the heading "Bobbin Alarm Does Not Work? Follow the instructions there.
If those steps do not get your bobbin sensor back in working order, I suspect you will need to have the bobbin sensor repaired by an authorized Husqvarna Viking sewing machine repair service.
I suggest you contact the Husqvarna Viking sewing machine dealer nearest you and ask about authorized repair businesses.
You can also contact Husqvarna Viking directly:
Toll free 1.800.446.2333
Monday - Friday: 8:00 am - 4:00 pm CST
[email protected]
Need a service manual for a viking SE sewing machine
Service and repair manuals are difficult to find as the manufacturers are reluctant to make that information available to the public. However, sometimes you will find them for sale on sites like eBay. If you also search the internet for parts diagrams you may find some information to help figure out where things belong.
There is also this site (I have no experience with it):
http://www.sewconsult.com/sewing_machine_service_manuals/sewing_machine_service_manuals.htm
Viking Designer SE missing the spool holder where can I buy one?
some authorized husqvarna viking dealers have websites where you can order the spool holder. Might just call an authorized dealer and purchase over the phone. Other 3rd party vendors are http://www.pd60.net and http://www.sewingpartsonline.com may have these. Hope this helps.
Password For Viking Designer SE
actuall she/he means is after you hold down the back and pivot foot button and turn on the machine, it will pop up with a dialog asking for a password..
Top Sewing Machines Experts
SmartAviator
SmartAviator
Are you a Sewing Machine Expert? Answer questions, earn points and help others
