Question about Panasonic Audio Players & Recorders
I have an old panasonic subwoofer/satellite speaker system with the old style connector and i need to connect it/adapt it to hdmi
6ya staff
SOURCE:
Anonymous
SOURCE: need wiring and 9pin connector diagram
Dell (Altec Lansing) A425 Subwoofer Pinouts
This is a standard female DB-9 serial port.
Here are the pinouts.
Pin 1 = Left Speaker Out +
Pin 2 = Left Speaker Out - (Common Ground)
Pin 3 = Left Line In +
Pin 4 = Right Line In +
Pin 5 = Left/Right line In - (Common Ground)
Pin 6 = Right Speaker Out +
Pin 7 = Right Speaker Out - (Common Ground)
Pin 8 = Power A
Pin 9 = Power B
Jumper (short) Power A to B to turn on.
If you want a volume control you need to put one on the inputs. You will buy buy a stereo volume control or potentiometer.
Here is some info on how to do this.
http://g4tv.com/screensavers/features/43665/Pump-Up-The-Volume.html
Cheers!
Posted on Mar 24, 2009
Anonymous
  • 104 Answers
SOURCE: need to connect panasonic sb wa730 to panasonic sa dp1 system
There is a subwoofer outlet at the back of the sa dp1 connect via cable to the inlet on your sub then on your sa dp1 remote press shif and subwoofer at the same time
Posted on May 23, 2009
Anonymous
SOURCE: Simple question?? how do I connect my Panasonic subwoofer to my denon receiver?
I have a very similar problem with the same exact Panasonic sub. I went to Best Buy and Radio Shack looking for an adapter, and they basically told me that one does not exisit. Apparently, Panasonic designed the home theater system specifcally so that it could not work if any part of the entire system was ever seperated.
Posted on Nov 15, 2009
Stephen Potts
  • 447 Answers
SOURCE: Replacing Panasonic SA-HT500 with Newer Model that has HDMI Input
ANY amp will be ok, as long as the wattage of your new amp does not exceed the wattage of your speakers. Otherwise you could overdrive your speakers and damage them. First clue, if you turn up the volume and the speakers start to shut off and on you are pushing too much power to them.
Posted on Feb 03, 2010
dunnbiker
David Dunn
  • 8546 Answers
SOURCE: Receiver cannot recognize subwoofer
As I implied earlier, take a clue from the physical style of connectors for both parts of the subwoofer function in the old and new receivers:
RCA connections are for Line Level signal between components only.
The input (bare wire) at the speaker is for AMPLIFIED signal.
You can't just modify one to fit the other and expect magic to happen. Be glad you didn't do it the other way around and modify an amplified (speaker level) outout into a Line Level input. You likely would have smoked that component.
Your subwoofer is a passive speaker, that is, like any other speaker it needs an amplifier. Many subs are self-powered (amp built-in) and they would mate well with the RCA sub output of the receiver.
Get yourself an Active (self-amplified) Subwoofer and run UN-MODIFIED RCA cables to it, according to its instructions, from the Sub Out of the receiver. Or get an amplifier between your receiver and the sub you have.
Posted on Feb 21, 2010
Testimonial: "Thank you for your help to an electronics layman!"
How do i connect a set of Harmon Karden HK695-01 speakers to a Macbook Pro Mid 2010
HI Marc
Follow the steps below
Step 1:
Connect the green connector from the subwoofer into the headphone jack on the laptop, the black connector is not used, leave the rubber cap on the black connector to prevent static from the pin grounding on the system.
Step 2:
Plug the orange connector from the right/control satellite into the orange jack on the subwoofer.
Step 3:
Plug the brown connector from the left satellite into the brown jack on the subwoofer.
Step 4:
Plug the AC plug of the HK 965 into the wall outlet
Step 5:
Turn on the speaker set and adjust the volume accordingly.
PS: Do not Forget to adjust the Laptop volume also to minimize Distortion. Enjoy!
Jun 04, 2015 | Harmon Kardon Hk695 - 01 Audio System...
I have a panasonic home theatre system Model No SA-HT690 and want to bypass the DVD player and hook it up directly to my new Samsung TV. I want to be able use the surround sound when watching TV and using...
I don't really understand what you want to do. The DVD player in the Home Theater, you don't want to use or doesn't work? In any case, the sub needs to be hooked up to the Panasonic, not the TV. The Panasonic doesn't have an HDMI out? If you let me know just what you're trying to do and why, I can be of actual help. I will also need to know what connectors are available to you, and on which unit.
Dec 07, 2014 | Samsung Audio Players & Recorders
My MacBook's audio still on even when harman Kardon speakers are connected to the computer.(Original version with USC connectors).
As I seem to recall the very first version was powered by the computer and as such may not be compatible with your Mac. I may be thinking of Apple's Clear speakers though? Do your HK Soundsticks have a power adapter or AC cord?
Oct 15, 2013 | Harman Kardon HARMAN/KARDON SOUNDSTICKSII...
I have the SB-HW950 subwoofer and teh SC-PT950 speakers and I just purchased a Denon Receiver to replace my DVD/ receiver player. So now I have SC-PT950 speakers playing through the Denon but for some...
Yes, the old Panasonic SC-PT950 did drive the subwoofer by its own amp, such as it was.
http://www.retrevo.com/support/Panasonic-SC-PT950-Home-Theater-Systems-manual/id/2869dj183/t/2/
It's never a good idea to adapt prescribed connectors to bare speaker wire or vice versa.
Speaker Level and Line Level signals are worlds apart and equipment damage may result. Your Denon (model unknown) probably requires a POWERED SUBWOOFER, to which it would provide Line Level LFE from its Pre Out.
Read the manual where it doesn't say to convert a speaker wire to RCA.
Feb 06, 2011 | Panasonic Audio Players & Recorders
I need pinout assignments for a Philips 5.1 Home Theater Speaker system (PWR2006-37)? It has a DB-15 style input connector that hooks to the output of a Philips dvd / amp / control unit. this was...
Pin assignment is as follows (not sure of levels required- preamplification / attenuation may be necessary:
1: Control 0/5V.
2: Unused
3: Unused
4. Center speaker in
5. Ground
6. Ground
7. Subwoofer in
8. Ground
9. Unused
10. Ground
11. Left Front speaker in
12. Right Front speaker in
13. Ground
14. Right surround (rear) in
15. Left surround (rear) in
Jul 10, 2010 | Philips DVP642 DVD Player
Feb 21, 2010 | Pioneer VSX-D607S Receiver
Please Help ....i have Bose Acoustimass 10, 5.1 system connected
Usually the LFE out is only a line out and is not amplified in any way, so first of all is your subwoofer self amplified or not? Cause if not, the LFE output won't be of much use to you. So if it's not self amplified you need an new amplifier to put between the receiver and the subwoofer. Any amp that supports RCA line-in input will do. Even a car stereo amplifier will work provided you can get a 12volt power supply to run it in the house. If the subwoofer is self amplified though, then all you need is to make an adapter cause none are readily available in stores to go from a RCA connector to 2 wires. You can buy a virgin RCA connector that you can wire yourself at The Source, Circuit City, or any electronics store you have locally, or if you have an old RCA to RCA wire you don't need anymore, you can just cut it in half, strip the 2 wires and you got you adapter right there.
Jul 07, 2009 | Bose Acoustimass 16 Speaker
May 27, 2009 | Panasonic SC-HT930 System
Do I set my DVD output into the 1100 on Bitstream or PCM ?
If you truly have a blu-ray player, it will have a HDMI port.
Feb 01, 2009 | Yamaha YSP-1100 Digital Sound Projector...
Sc-ht500 system cable
You cannot wire this system separately, since it is very difficult to separate the power cables from the others which carry the audio parts.if in any case , lets suppose, you could wire the dvd player separetely, you will have no audio since all the audio frequencies are transfered in this cable to the sub woofer and from there to the satellite speakers.
It would be useless to wire it even if we could as there would never be any audio, only video, no matter what disc you use as the only way the audio is comming is throught this system cable to the subwoofer. Actually its the worst idea to implement in a home cinema system, but well, this is old panasonic.. :)
Aug 11, 2007 | Panasonic SC-HT500 System
52 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
John Wardlow
John Wardlow
Level 1 Expert
Ekse
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
