Question about Rangemaster Kitchen Ranges
I have a rangemaster 90 classic range cooker. The clock has stopped working and neither oven works. Is there a safety valve to cut the gas to the ovens? And how can I repair the fault? There is a power supply.
6ya staff
SOURCE:
douglas smith
  • 1462 Answers
SOURCE: Zannussi Gas cooker
make sure clock is set properly - refer to your instruction book. to test if clock is in fact faulty, access the clock and bypass it by shorting together the two wires to the clock relay
Posted on May 04, 2007
Anonymous
SOURCE: leisure rangemaster 55 gas cooker
It sounds exactly the same as I am experiencing on my oven of the same model. My theory is that the full flame gas is controlled by a thermostat, and that this has broken hence why the oven only stays on preheat. This will be a matter of a replacement part. Most likely the thermostat is a bi-metal strip that, because it has heated and cooled so many times in it's life it has simply finally given up. Try searching online for the correct part and get a corgi registered fitter or another suitably qualified fitter to come and replace it.
Posted on Apr 07, 2008
Anonymous
SOURCE: clock on cooker flashing
Just to let you know that i have solved the problem with my cooker, (clock flashing after electric going off) i held down the cook period button and the end time button, then i was able to reset the clock by pressing the +button.
Posted on May 01, 2009
Anonymous
SOURCE: their was apower cut now the clock and fan oven
where you clock is the buttons next to it, 2 have a line underneath joining to them both, hold them both down together to stop clock flashing, this will then allow your ovens to work, it's a safety feature on these ovens, and to reset clock keep both buttons held in and use the plus and minus button to set hope this helps Donna
Posted on May 09, 2010
John Fernie
  • 52 Answers
SOURCE: I have a Belling 652BL
ISOLATE MAINS POWER BEFORE OPENING SIDE AND REAR PANELS.
The grill and top oven have as discribed in the manual a temp regulator it is mounted on the side or rear chassis, this is probabily blown, they are normaly connected, when the devise goes faulty it stays open circuit, there are letters and numbers on this, take a note of them if you can read it. go to a local electrical store with the component, you should get a replacement, if however you have a multimeter, measure across the terminals with the meter on resistance, if no continuity, or contiunity to the case, the component is faulty. If however the component checks out working go to timers and remove the time on the auto timer for the top oven, visualy check the elements if the element have Black Grey spot, replace as it has blown, you can get spares at relativly low price you will need model and serial number of the appliance, from whitegoods.co.uk
hope this has been helpful
johnf1
Posted on May 17, 2011
Testimonial: "Had a chance to investigate yesterday, and it does indeed appear to be the temperature regulator at the rear of the cooker which is faulty. Thanks fo"
I have a rangemaster classic 90 dual fuel..we have changed the spark generator. Now it sparks on all burners but when the oven is lit the sparking continues on all burners, how do we stop this?
Hello Stephany,
this cooker has an ignition system by pressing the knob of the item that you want to ignite.
As all sparkplugs work and only the oven is the source of the problem, i think that the contact behind the knob of the oven sticks
It looks like this one and is behind the facia, between the knob and the valve.
I hope this helps, Dik
Mar 25, 2017 | Rangemaster Kitchen Ranges
Rangemaster 55 leisure. My timer has stopped working
Hi Stella,
i am sorry for you, but you can forget repairing the timer.
You can replace it of course.
You do not need the timer to operate the oven.
For that you need to bypass the timer. The clock will stay working normally.
Although the 55 is smaller then the 110, the working of the clock should be the same.
Net link will give you more information and I hope you will fin the solution there.
Kind regards and a good weekend, Dik
Leisure Rangemaster 110 Electric Range Cooker How to bypass
Feb 28, 2017 | Rangemaster LEISURE 55 & 110 FAN OVEN...
We bought a brand new dual fuel Rangemaster cooker and the adaptation of our bungalow and building works have now been completed and ready for the cooker to be installed. However, my husband ( who has a...
I used to have the same range with 2 electric ovens, but it is available with the lower large oven on gas and the tall oven electric.
The manual for theToledo with tall electric and large gas oven can be found here:
http://www.rangemaster.co.uk/Siteimages/Site_311/BigMedia/Toledo90Gas.pdf
The manual for theToledo with both electric ovens can be found here:
http://www.rangemaster.co.uk/media/575792/toledo%2090%20dual%20fuel.pdf
The main product page for the toledo 90 can be found here:
http://www.rangemaster.co.uk/range-cooking/toledo-90.aspx
Sep 16, 2011 | Rangemaster Toledo 90 (Dual Fuel) Dual...
Their was apower cut now the clock and fan oven wont work. but power to the grill and gas is still functioning . rangemaster 110
Apr 15, 2010 | Rangemaster 110 (Gas) Kitchen Range
New applaince can't set clock, cannot switch on eletric ovens, electric grill works, gas hobs fine
I'm sure you must have had an answer by now, but just incase anyone else has the same issue. The ovens don't work unless the clock has been set (happens after a power cut). To set the clock you need to hold down the left-hand two buttons (underneath the clock) and at the same time press either the + or - button.
Oct 19, 2009 | Rangemaster Classic 90 (Electric) Kitchen...
Don't know what electricity supply is required
Emmet in luton: what fuse does a rangemaster 90 duel fuel need?
Apr 10, 2009 | Rangemaster Classic 90 (Electric) Kitchen...
Clock
My oven stopped working due to a problem with the clock, i coudn`t get the clock off of p100, ( clock broken probably chip broke). So i by passed the clock by removing the blue negative wire just by pulling it out of connection. (easy) took seconds to fix.I don`t need to use a clock, so i dont need to replace it. So simple to fix, anyone can do this.
Aug 12, 2008 | Rangemaster Classic 90 (Electric) Kitchen...
Rangemaster classic 90
Regardless of the clock running, if the timer is not set to zero and off, the oven will not function. See my instructions on using the timer (http://www.fixya.com/support/t1416237-timer_instructions_rangemaster_toledo) I hope that this is your problem and it will show you how to get the oven going again.
Aug 10, 2008 | Rangemaster Toledo 90 (Dual Fuel) Dual...
Rangemaster Toledo
we had the same problem - a power cut then the clock flashed up 'auto' preventing the oven from working.
After downloading the manual from the rangemaster website we learnt that all you need to do (for the classic dual fuel anyway) is to press in the 2 buttons on the left and set the time using the + or - keys. Dead easy and Christmas dinner is back on!
Sep 02, 2007 | Rangemaster Elan 90 (Dual Fuel) Dual Fuel...
Kitchen Ranges Logo
Top Rangemaster Kitchen Ranges Experts
Ismael Rodriguez...
Thomas F. Schneider
Archie Ferrarini
Archie Ferrarini
Are you a Rangemaster Kitchen Range Expert? Answer questions, earn points and help others
