Wait for the power light to stop flashing before turning off the product. If you just replaced an ink cartridge and the power light is still flashing after 3 minutes, the cartridge may be installed incorrectly. ... Ink in a cartridge is low. You can continueprinting, or check which cartridge is low and replace it.
SOURCE: epson stylus c42 plus
If both red and green lights are blinking, it usually means that your waste ink pads need replacing. This requires dismantling of the printer and resetting of the protection counter. If you feel up to it, respond with your e-mail address and I will send you instructions - but it's not easy.
SOURCE: blinking red light
Red Light blinks when the ink cartridge is bad..
to check which one is bad..
take out all cartridges from the printer and clean the copper contact and the inner area of the cartridge slot with a lint-free cloth...
power off the printer and unplug the power cable from the printer..
press & hold the power button on the printer for 60 seconds..
connect the power cable and power on the printer..
insert any ONE cartridge and close the door..
similarly insert other cartridges one by one and close the door and check if the light blinks..
if it blinks ..it means the respective cartridge is bad and replace it..
if u have replaced all the cartridge..it might be possible that the cartridge sensor inside the printer have gone bad..
if this is the case so ..u might service the printer..
but I will suggest to go for a new printer as 7660 is quite an lod printer which hp launched in 2004 or 2005..
even if u have juz bought it ..it will be refurbished one..
SOURCE: EPSON R1800 END OF SERVICE LIFE
You have a few choices on this one.
1. The SSC utility mentioned by Jacklee366 is usually the first port of call but it may not work in some situations. Worth trying regardless
2. Epson have an official reset utility which is available to North American printer owners who have a valid serial number (back of your printer).
You just fill out this form and you will then get access to the utility (the one eagleflh/bos_dsl is reselling with his kits)
3. You can also get access to the official service utility that service engineers use on these printers... A copy is available here.
IMPORTANT: This utility is a lot more powerful than the other two and requires a bit more hoop jumping but it can resolve the maintenance request very efficiently. Whatever you do, read the readme files and take your time if you opt to use it.
Hope that helps.
SOURCE: two red light blinking
Do you see any flag message like " end of service life-------". You should find a resetter for the printer, its a utility program.
Or its a paper jam, or dirty ink chip connector.
