SOURCE: Kirby Belt Lifter Assembly
I have tried to get a parts breakdown for your vacuum cleaner with no success. The way that then washers should go is the flat smotth metal washer on the inside followed by the fibre washer and the wavy washer on the outside. The waves are used to bite into the plastic so it cannot work loose.
SOURCE: Engaging belt on Kirby G5
first things first...take the powerhead off of the front of the kirby. If you look at where the powerhead connects to the front of the kirby you'll see a large hook...turn the hook using the crank on the front of the powerhead so that the belt is pulled up and away from the brushes. The hook stretches the belt so that it can fit over the fan drive.
Next, place the two "feet" of the powerhead onto the "perch" on the front of the kirby....lock it on by turning the silver lever on the top of the kirby (the one under the hood/light)
then turn the belt lever from off to on.
the G5 should have a light on the powerhead that comes on (green) if the belt is spinning the brushes. That will let you know if you've got it on correctly.
SOURCE: changing belt on Kirby Classic 1972
When you turned the knob, did it turn easily or hard. If it was easy, then the knob part inside did not catch the belt. If it did turn hard, when you had the brush roll off, did you check the ends to see if they turned easily or not. if not, then replace the brush roll.
SOURCE: Hi....Need Help please....
Put the belt on the brush roll, place it in the nozzle, make sure the belt is in the center, turn the big knob on the front until it locks, then install the nozzle on the vac., turn the knob in the other direction, and it will be put on the pulley.
SOURCE: Kirby belt attachment
Try this link, Its all about how to fix your problem.
http://www.greatvacs.com/Kirby%20Brushroll.shtml
