Happened while cleaning
A very simple solution to r epairing all by yourself is getting help from handbooks, they're very detailed and complete in every way so for me it was my best source to repair
one of the to p sites for this is https://big-manuals.com/
SOURCE: "Door Locked" flashing on GE Oven JTP15 - can't unlock
The problem may very well be in one of the micro switches on the self cleaning motor bracket. These switches control the electrical flow to the heating elements. In the owners manual there is/should be a chart that lists the unlock and safety combinations. This would be your best source of information.
SOURCE: GE Oven not working
hi
you may need a new control board. if your stove is in warranty contact the manufacturer, if not and you are handy you can find a replacement online and install it yourself. just be sure to unplug the stove before you work on it. if you need help with this please contact me.
SOURCE: install electric walloven under gas cooktop
cheked on installation guide available with product online
SOURCE: GE JCB909 Range - Blank display
The problem was not with the stove, it was with the electrical box - it was wired incorrectly.
Even though power was getting through it was not the way it should be. Electrician made repairs and stove appears to be functioning correctly.
SOURCE: GE Electric Double Oven Door Will Not Unlock
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have usedthe self cleaning option. Thanks for the info!! " - amymrocks
