SOURCE: Memory Full Error
to use a memory card u have to check the manuel probably u have to buy an mmc card for storing pictures and videos as it is an sd card u have to first dormat it u can do it inside a mobile phone also
SOURCE: Unlocking memory card
http://www.pentax.de/downloads/photo/uk/Optio%2060/Optio60_Manual_web.pdf
pg 17 at the bottom shows how to unlock the card, but it is simple, take out the memory card and on the side of it will be a little tab which can slide, slide it off the lock position and it should work
SOURCE: Memory card locked!??
What you need to do is take out the card, and on the side of it there should be a little gray thing which can slide up and down. It needs to be slid all the way up. I hope this helps!!
SOURCE: 4gb Memory card error
In order to use 4gb memory your camera has to be approve for SDHC use.
If it isn't the most memory you can put into your camera is 2 gb
SOURCE: My Pentax Optio E40 Camera
The built-in memory only has about 8 pictures or so. You have to buy a memory card to insert in the same section where the batteries are inserted.
