Peter campher Posted on Dec 06, 2018
MY GESTETNER PRINTER SHOWS ME 838 2701 0XFFFFFFFF ERROR CODE CAN IT BE FIX AND HOW TANKS
3 Related Answers
Anonymous
  • 96 Answers
  • Posted on Feb 09, 2008
SOURCE: gestetner printer error sc371
SC371 YellowiD Sensor Detection Error
Anonymous
  • Posted on Jan 17, 2009
SOURCE: Gestetner DSM645SP Error Code SC 322
After research it seems this problem is not easily fixed.
gggg
  • 904 Answers
  • Posted on Jul 29, 2010
SOURCE: gestetner dsc38 error code
sc386 is a color density error specific to black, but it usually is caused by the development unit rather than the drum. If the drum is old or worn you may want to replace it, but almost every time, replacing the DV unit will get rid of the sc386 error code.
Error 120 code
To reset the SC code follow these directions:
Resetting Ricoh Savin Lanier Gestetner SC Error Code
Error code 120 is scanner home position sensor problem. If it's a recurring problem, here are some troubleshooting tips:
SOLUTION:
Turn the main switch off and on.
Check the wires between Home Position sensor and the SBU.
Fix scanner board or the SBU .
Check the wires between scanner motor and the scanner I/O board
Fix the scanner motor.
Fix the Home Position sensor.
Fix pulley, timing belt, the scanner wire,
Fix the carriage.
3helpful
Ricoh Aficio SP 4210N- Code SC 543
This is a common error code for Ricoh copiers, Savin and Gestetner copiers that need service. Recently Ricoh has purchased Lanier and now is naming all their new machines Lanier instead of Gestetner, Savin and Ricoh. However, the copier service error codes have remained he same.
When you get this copier printer service code it means the fuser or fixing assembly (same part) has thermistor problem. The copier fuser's thermistors help regulate the temperature of the fuser assembly. The fuser assembly on all copiers including Canon, Kyocera, Ricoh, Sharp and other brands is the part that melts the toner onto the page.
Getting back to the repairing the copier on Ricoh, Savin, Lanier and Gestetner models that have the fuser or fixing code error. The majority of the time the fusers' thermistors (Middle and read) need to be replaced. Just cleaning them will not solve the copier repair service code.
It is usually, depending upon the machine, its a 1 to 2 hour copier repair job because the copier repair service technician will need to dissemble the fuser, insert the two new thermistors, re-assemble, reset the error code and test the copier machine repair. Also, ask the copier technicians to to do a copier cleaning maintenance while on site.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
5helpful
Gestetner 6123cp gives E-06 error. Can you help me?
Gestetner cp 6123p+ shows E-06 error.
please i need your help ?
1helpful
I have Gestetner DSM622 SP, Iam getting Errer code SC546, can someone explain me thanks
sc546 is a fuser temperature detect error. One or both of the thermistors most likely need to be cleaned or replaced, but you will have to go into service mode to reset the code once you do that. You should contact your local service technician or Gestetner dealer, as they can easily fix that problem.
3helpful
2answers
LANIER LD245 SHOWS FUNCTIONAL PROBLEM SC542
This is a fuser temperature control error code. Could be as easy as resetting the code and rebooting or it could require parts such as a thermistor, thermofuse, heat lamps. Typically though its the thermistors, the sensor that reads the temperature from the heat roller surface.
3answers
Gestetner-2412Z copier-error code UF
UF is a panasonic code,the u means user fix.If you have an users guide it will tell u what to do.
Top Gestetner Office Equipment & Supplies Experts
Daniel Blask
Daniel Blask
ZJ Limited
ZJ Limited
Are you a Gestetner Office Equipment and Supply Expert? Answer questions, earn points and help others
