Heating & Cooling Logo
Posted on Aug 04, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My problem is in addition to moisture near some duct outlets the thermostat always go 2 degrees below the set limit .I also have a carrier infinity system installed only 1 yr, had the problem from the begining, but carrier and Sears are not able/ not interested after selling the unit.
t1m130
Level 2:
  • Expert 86 Answers
  • Posted on Aug 04, 2009
t1m130
Expert
Level 2:
Answers
86
Questions
0
Helped
36913
Points
178
If you have a mercury thermostat and it is not leveled properly it will turn the temperatyure on and off by a couple of degrees
some thermostats have the capability of running the unit longer than the set temperature
i would recommend calling a local heating and air conditioning contractor and get the unit cleaned and bring up the issue then
Powers on, then immediately shuts off. More detailed in comments below This is too aggravating!!!!!!! Characters characters
Hello Kathy: All clothes dryers work on the same basic principle...
1.) Air Flow
2.) Heat
3.) Rotation
Your problem may lie in your duct work configuration and how the exhaust gases are vented; the mere fact that you had blockage could have overheated the dryer's high limit thermostat and/or the thermal fuse...BUT, before I go any further...I need to talk to you about safety!
Gas dryers give off combustion gases that are toxic and DEADLY; DO NOT VENT YOUR DRYER UNDER YOUR HOUSE SLAB to the outside! Especially that you report that it gets WET inside that underground slab- it's against NFPA fire codes (municipal and state building codes, as well) to do that. If that slab ever collapses partially or fully, you'll have no way of knowing it and the toxic gases will back-up into your house.
The safer venting method should be done with 4 inch solid wall vent pipe; and should be vented directly outside. Maximum duct work (straight run of ducting without the use of any elbows) for your model gas dryer, is 65 feet.
If you are using 1- 90 degree, the total length reduces to 55 feet, including the elbow in that measurement
The use of 2- 90 degree elbows, 47 feet; for 3- 90 degree elbows, 36 feet, and for 4- 90 degree elbows, 28 feet- maximum length.
These are per your manufacturer's installation specifications.
Although you should not use more than 4- 90 degree elbows in your configuration, in the event you do, you would deduct 6 feet for each additional elbow used. You want to make sure that you can visibly see the vent pipe (to visually inspect it for defects or for ease of access to clean and service)- and never keep flammables of sorts near the vent pipe due to the heat that they radiate.
I choose solid vent pipe over foil or plastic (in my home, rental properties, and when I do installs) because lint does have a tendency to burn inside the duct work...which could lead to perforation and/or fire. Plus many manufacturers recommend solid vent pipe over other types; and I do not recommend using screws to connect solid vent pipe together with, since lint can catch on the exposed screw that protrudes into the duct. Use a combination of, heat rated duct tape and dryer vent clamps.
Some installers or readers of this will think that this is excessive, costly, and not necessary; through my life's experiences, I have seen unfortunate yet avoidable tragedies. (Don't forget to check & clean your dryer ducts at least once-a-year!- I do mine at the start and end of DST- the same day we change the clocks and the batteries on our smoke and carbon monoxide detector alarms.)
Now, concerning the rest of the troubleshooting process, are you getting any trouble code errors on the electronic panel? If so, what are they?
You have several choices, you can disconnect and remove the high limit thermostat and thermal fuse and check them for continuity or call tech support using their smart diagnosis procedures as outlined on page 35 of you owner's manual. Or you can disconnect the dryer at it's power source (outlet or circuit breaker) and wait a half hour; see if the electronic computer panel resets. Then try running the dryer.
Please let me know how you made out or if you need more help.
I have the carrier infiniti system. When my thermostat reaches the set temperature it doesn't always shut off. I shut off the main control to let it reset. It works for a while and then it starts
Carrier Infinity system is a variable speed unit that will just slow down as it approaches set point. Unless it overshoots the set temperature (you have it set on 72 and the temperature keeps rising above 72) this just sounds like normal operation.
Replacing themostat
Please see my tip at http://www.fixya.com/cars/r5929960-s_thermostat . These are generic instructions. Specific instructions for your car are provided below. please get back to me with any questions.
procedure from autozone.com:
3.4L Engine
  1. Disconnect the negative battery cable.
  2. Remove the air cleaner and duct assembly.
  3. Partially drain the cooling system into a suitable container, to a level below the thermostat.
  4. Disconnect the radiator hose from the coolant outlet.
  5. Unfasten the coolant outlet retaining bolts.
Fig. Fig. 3: Unfasten the bolts and remove the coolant outlet
  1. Remove the outlet, then remove the thermostat.
Fig. Fig. 4: Once the outlet is removed, you can remove the thermostat
  1. Thoroughly clean the gasket mating surfaces.
Fig. Fig. 5: Location of thermostat housing and outlet on engine.
To install:
  1. Install the new thermostat with the pellet towards the engine.
  2. Install the outlet to the intake manifold. Apply RTV sealant to the housing bolts and tighten to 18 ft. lbs. (25 Nm)
  3. Reconnect the radiator hose to the thermostat coolant outlet.
  4. Install the air cleaner and duct assembly.
  5. Refill the coolant and check for leaks.
When adding coolant, it is important that you use DEX-COOL® (orange colored, silicate-free) coolant. If silicate coolant is added to the system, premature engine, heater core or radiator corrosion may result. In addition, the engine coolant will require change sooner.
  1. Connect the negative battery cable.
1helpful
Dryer does not heat . I'm sure i can replace what's broken , just need to know which part controls the heating.
cf551e5.jpgThe cycling thermostat controls the heat. Notice the 4 wires. Their 2 small wires and 2 large wires. The small wires operate a tine heater inside the control. If I want to dry knits I would heat that control up so that it would cycle at 130 degrees instead of 160 for cottons.Cycling thermostats rarely go out. They are always mounted on the blower housing. Those other themostat's you see near the element are high limits. Their is a 250f limit and a 300f limit and if they both fail their is a duct fuse which is rated at 350f and tied into the door circuit on electric dryers and gas assembly circuit on gas models.cf46369.jpg237451a.jpg9679563.jpg857d34a.jpg
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
May 22, 2010 • Dryers
Takes too long to dry a load.
HI, Check the following to address this issue further.
Note: Normal drying time for a dryer is about 45 minutes (some may take up to an hour).
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat. These thermostats are located in the dryer vent duct and sometimes mounted on the blower assembly as well.
To test the thermostats, set the multimeter to the ohms setting X1. Touch one probe to each terminal. You should get a reading of either zero or infinity. At room temperature, the thermostats should have a reading of zero. When the thermostats are heated to their limit temperature, they should switch off and you should get a reading of infinity. Replace any thermostat that fails this test.
Dryer smells hot and back panel near heating
your duct is clogged or the limit snapstat is not working. turn dryer on and go outside to the duct vent , their should be a minimum temp of 10 degrees, and a maximum 15 degrees outside. also sometimes just cleaning the lint from inside the dryer, can cause this smell for no more than 5 minutes. thanks karl
It's taking 2 or 3 times to fully dry my clothes! even on small loads
1. Venting
2. Thermostat
Thermostat Testing Procedure:
HI. To test the thermostats or fuse, set the multimeter to the ohms setting X1. Touch one probe to each terminal. You should get a reading of either zero or infinity. At room temperature, the thermostats should have a reading of zero. When the thermostats are heated to their limit temperature, they should switch off and you should get a reading of infinity. The fuse should be tested at room temperature for continuity.
2helpful
2answers
Problem with new Carrier Infinity 96 gas furnace
carrier infinity 96 furnace went to turn down the thermostat and their was no power to it and the furnace doesnt run
2answers
Dryer will not heat
the limit switches are known to go bad on dryers
2helpful
2answers
Carrier Air Conditioner Infinity System - Air Handler Sweating & Duct Work Condensation
Either its not drainning mositure properly or low air flow across the "A" coils- caused by dirty filter .
Top Heating & Cooling Experts
Paul Carew
john h
