SOURCE: Wiring diagram for a Dayton thermostat
Contact Dayton on the internet for this problem. The diagram should be available on their site. Or they will give you a number for customer care. They can give you step-by-step instructions. I am a technician and this is what I would do as their are millions of wiring diagrams. Many are noy up to date.
Ray
SOURCE: replacing a dual burner control switch
First, have you removed the wires from the old switch?
If not, then look on the switch, old or new, and see if there are numbers on the terminals. If so, just move the wires one at a time, terminal number to terminal number.
If you have removed the wires, then you will need to find the wiring diagram, which is most likely found somewhere inside the unit or on the back panel. You should be able to identify the correct wire connection from the wiring diagram.
If you can reply the full model number, I might can find a wiring diagram for it and give you more direction.
SOURCE: Wiring/Replacing pull chain ceiling fan switch
Sounds like it to me that the netual is not there.
SOURCE: I lost my Leviton 6230M 30 mins timer installation sheet.
Switch has 2 black wires. One black is hot wire. One black is wire going to fan. Turn off power. Remove wires from switch and separate. Turn power back on. Using ordinary tester, test each black wire to bare copper ground wire. Only one of the black wires will test hot. The other black wire goes to fan.
Timer black wire connects to black hot
Timer blue wire connects to black wire going to fan
Timer white wire connects to white neutral (in absence of white neutral, connect Timer white wire to bare ground)
Timer green connects to bare ground wire
SOURCE: Where can I find a replacement switch. Zing Ear
Hi Eric...
Click here Amazon com zing ear switch and chose the best one for you. Anyway contact the seller before buying, to see if fits on your model. I hope this helped.
enjoy
