Question about Frigidaire Ovens
Trying to figure out if my microwave needs to be replaced due to broken left bottom hinge
Over the oven, Frigidaire professional series plmvzw169gcc it was manufactured Jan 2008. some can be fixed by tightening a screw?
6ya staff
SOURCE:
ashburton
  • 417 Answers
SOURCE: Smeg oven door off hinges
Try www.smegtech.com/site/smeg/pdf_libretti/914772524-GB.pdf section8
Posted on Oct 19, 2008
Anonymous
SOURCE: How can I remove oven door so that I can replace the broken glass
I just took my oven door off and took it apart to clean the glass inside. I don't have a maytag but they probably all work alike. Just open the door like you are going to broil something and just lift it up. It should slide right off. Shouldn't have to unscrew anything. Hope this helps. Arlene
Posted on Nov 15, 2008
Anonymous
SOURCE: I need to replace the outer glass on my Advantium oven
contact GE; they should have replacement glass in stock.
Posted on Jan 15, 2009
Anonymous
  • 7 Answers
SOURCE: F30 ERR message on Frigidaire Professional Series Range
I am a tech and just had this happen to me, so I can feel your frustration. I have replaced the temp probe, erc, and still had the problem.
Open the back, with the unit unplugged. On the lower right hand side there is a relay, beside the relay there is a "safety T-stat" disconnect from the circuit by removing one wire and read for continuity. If none is detected, replace t-stat and voila... stove works. Much cheaper than erc and probe...
Posted on Sep 12, 2009
Anonymous
SOURCE: Bosch Oven Door Problem - doesn't close at top
On our oven (Bosch Evolution 700 Series HGS7152UC), the problem was getting worse and worse. I found it is was worsening simply because the hinges had started to come loose. I removed the door as suggested above, and although there are no adjustment screws on this model I tightened the now-loose hinge mounting screws. For each hinge there are three screws altogether: two (phillips heads) on the bottom of the door and one (torx head) on the inside wall of the door. After tightening those screws it is a lot better, only leaks as much heat as it did when it was new which is tolerable. Still a bad design.
Posted on Dec 09, 2009
The oven was cleaned recently. Since then, it will not heat up. Instead 135 and prebake, on appear. Cannot get rid of this. Help?
Hey Mark, thank you for your submission!
Based off the information you have provided your Frigidaire oven is no longer heating up after it was cleaned. The oven may need to be reset in order to help clear out any miscommunication. In order to reset the oven you would need to flip the household circuit breaker off for at least ten minutes. If the reset does not help clear out your issue I would suggest seeking assistance from a professional technician. You can locate a technician in your area from your manufacturer's website. I hope that this information is helpful. -Matt
Feb 21, 2016 | Frigidaire 30 in. Electric Gallery Series...
My Frigidaire gas oven won't light but broiler does light
Hello friend, thank you for your post!
From what you are describing it sounds like a potential issue with your control or pressure regulator within your Frigidaire oven. I would recommend seeking assistance from a professional for further help regarding the oven not lighting due to the gas.
If you need assistance connecting with a professional technician you can visit the manufacture's website for further help. -Matt
Oct 04, 2014 | Ovens
Clean between the glass on double wall oven
Unscrew the handle and screws at the bottom. Carefully separate the outer panel from the frame
Apr 09, 2014 | Frigidaire FPET2785KF Professional Series...
Es510
Hello KC - You may try and reset the cook top by disconnecting the power to the unit for up to 30 seconds by flipping the circuit breaker off and back on. This often clears most false error codes. If the lock symbol does not clear, then the unit more than likely may be experiencing an issue with the EOC (Electronic Oven Control), user interface board or a potential wiring failure. This is not a typicaly do it yourself job; please consult a professional or your manufacturer.
Apr 28, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
Ned's to know witch relay to replace wich f8 problem
Hi there! Typically for such an error code, F8 or F80, there is a communication error between the UI (User Interface) and the control board (often the microwave control board). Yes you have a microwave control board in a double wall oven. This will require either the main control board or the UI board being replaced by a professional for safety reasons. I would suggest to contact a professional that partners with your manufacturer. Contact your manufacturer first to see if there are any known issues or a limited warranty for your model.
Mar 30, 2013 | Frigidaire 30 in. Electric Gallery Series...
Frigidaire oven
Sounds like your control board/panel has shorted out. You would definitely need a professional to diagnose correctly and properly repair.
Dec 26, 2012 | Frigidaire 30 in. Electric Gallery Pro...
Frigidaire Gallery Professional Series - No clock/oven functions
i have an old model of the fridgedare gallery professional series stove. After self cleaning, the ignition sparks for the burners will not come off, they keep clicking and only stops when i pull out the plug. can you help me with this situation?
Nov 01, 2008 | Frigidaire FGB24S5A Gas Single Oven
Ovens Logo
Top Frigidaire Ovens Experts
Marvin
Marvin
Bruce Denton
Alan Chouinard
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
