SOURCE: Items sometimes freeze on refrigerator side of unit - model GSS25LGMA
It is most likely a bad damper motor. This is where the cool air comes out into the fridge section. On this model it is a fairly common problem and comes a whole assembly. The part # is WR49X10091 and will cost anywhere from $100 to $122. Knowing this model I would bet this is your problem. If the damper is bad and stuck open cold air will just keep blowing in. It is suppose to open and close based on the temp setting. Let me know if you have any other questions.
SOURCE: LG refrigerator not working
Check and clean the condenser. Unplugging the system allows it to cool off. when you plug it back in it will cool until the heat rebuilds if not rejected through the condenser. Make sure the condenser fan comes on when the compressor runs. A faulty fan motor will cause the same type of problem.
SOURCE: FRS26KR4CB1 side by side refrigerator
How to replace start relay on Whirlpool Side Ref.?Insrtuction sheet Please!
SOURCE: Whirlpool runs, but freezer not freezing and frig not freezing
If the compressor is running but the unit is not cooling you may have lost the refrigerant. See if the condenser coils at the back or bottom are hot. If they are only warm then the refrigerant is low and can be recharged. Service tech should check for leak in coolant system.
SOURCE: My Samsung Refrigerator can not keep the set temperature.
Normally your fridge is set +2 degrees C. with a differential of 3 so when it reaches +5 it should switch back on. if this is not doing this then a new thermostat may be in order.
