R
Rick Gray Posted on Dec 01, 2018
How to reset memorex MHTS 2137s soundbar - Memorex Audio Players & Recorders
How do I reset Onn Soundbar model 100069413 with or without using the remote control?
To reset your Onn Soundbar model 100069413, you can try the following steps:
  1. Using the remote control:
  • Press and hold the "Volume Down" button and the "Source" button on the remote control simultaneously for about 5 seconds.
  • The soundbar should turn off and back on, indicating that it has been reset to its default settings.
  1. Without using the remote control:
  • Unplug the power cord from the soundbar and wait for about 30 seconds.
  • While the power cord is unplugged, press and hold the "Power" button on the soundbar for about 5 seconds.
  • Reconnect the power cord to the soundbar and turn it on.
If these steps do not work, you may need to refer to the user manual or contact the manufacturer for further assistance.
My woofer will not pair with the sound bar vht215 model
Here are some troubleshooting steps you can try to pair your woofer with your Vizio VHT215 soundbar:
  1. Power cycle: Turn off both the soundbar and the woofer and unplug them from their power source. Wait for a few minutes before plugging them back in and turning them on again.
  2. Reset the soundbar: Press and hold the Bluetooth button on the soundbar until you see the light on the front panel start to flash rapidly. This will reset the soundbar and put it into pairing mode.
  3. Reset the woofer: Press and hold the Pair button on the back of the woofer until you see the light on the front panel start to flash rapidly. This will reset the woofer and put it into pairing mode.
  4. Check the distance: Make sure the woofer is within the recommended distance from the soundbar. Typically, this is around 30 feet or less.
  5. Check for interference: Other wireless devices or electronic equipment in the vicinity can interfere with the Bluetooth signal. Move any such devices away from the soundbar and woofer, or turn them off temporarily.
  6. Replace batteries: If your woofer uses batteries, make sure they are fresh and installed correctly.
If none of the above steps work, you may need to contact Vizio customer support for further assistance.
My plustron fr270 cuts out after 5 seconds thanks,help required please.
Please try to update your soundbar by following the steps below:
  1. On the remote, press the SoundTouch button.
  2. Press and hold the Closed Captioning button until the Wi-Fi indicator, TV indicator, SoundTouch indicator and Bluetooth indicator on the soundbar blink white.
  3. The soundbar restarts when the update is complete.
    Note: The update may take between 8 and 30 minutes. Update time depends on wireless network activity and other wireless interference in the area.
If this does not help, try to factory reset your soundbar:
  1. On the remote control, press the SoundTouch button
  2. Press and hold the Teletext button (to the right of the CC button on the remote) for 10 seconds until the Wi-Fi, TV, SoundTouch and Bluetooth indicators blink white on the soundbar
    The soundbar restarts and the Wi-Fi indicator on the soundbar glows amber (setup mode) when the reset is complete
  3. Restore the soundbar's network and audio settings by launching the SoundTouch app on your smartphone or tablet, add the system to your network and run the ADAPTiQ audio calibration
The soundbar connected to my TV stopped working after I accidentally reset the remote. TV is Spectre X405BV and soundbar is a Samsung HW-K450/ZA.
By "reset the remote," did you mean you reset the TV to factory defaults? If so, you would need to reconfigure your sound settings.
HOW CAN I MAKE A HARD RESET FOR AN LG SOUND BAR WITH CODE NB2420A
To do a hard reset for LG soundbar las450h or 550 series, long press the volume min button on the soundbar and sound effect button on the remote simultaneously for 10 secs and the soundbar screen will show reset mode. Switch off and switch on the soundbar.
Having trouble getting the subwoofer and satellite speakers to work with the soundbar.
hello anonymus if your system is working and the soundbar does not
make sure you have the right connector to inject signal to soundbar some of them like you have has a tiny hole to reset it and dont forget to use the remote control i hope it works
17helpful
2answers
How to pair my soundbar and wireless lg soundbar
Press and hold the reset button on the back of the subwoofer until the light on the front starts blinking. Then with the soundbar turned on, press the stop button on the soundbar and the mute button on the remote at the same time. The display should say "REMATE". The sub light should stop blinking then and should be linked.
4helpful
2answers
Reset my soundbar
Amp is probable going into protection mode. Disconnected all speaker and av wires (only power) and check if it switches on. Try to plugged it in also at another wallsocket. Presume PSU damaged by surge
4helpful
2answers
How can I reset my Philips Soundbar system
You just remove batteries , unplug all cables, then put everything back together. This will reset the unit to factory settings.
Top Memorex Audio Players & Recorders Experts
 Grubhead
Grubhead
Paul Bade
NOEL
NOEL
Are you a Memorex Audio Player and Recorder Expert? Answer questions, earn points and help others
