Question about Polaroid P3500S Id Card Printer System
I have a Polaroid P3500S printer that gives me a "Printer Problem 103" message when trying to print. I have shut the printer down and back up but each time it gives me the message.
What could be some possible things to look for that would be causing this? It has a good ribbon in it as it worked on another printer.
6ya staff
SOURCE:
yooperbud
Weldon Dube'
  • 8637 Answers
SOURCE: LexMark Z23 printer error message
Normal 0 Could have a corrupt driver.
Disconnect the printer or at least be sure it is turned off. I'd do both and when the CD software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 30, 2009
Anonymous
SOURCE: Tec 572 printer gives "no ribbon" error with ribbon installed
You have to set the ribbon type to be "non-transmissive" for black transfer film.
To set the ribbon type, turn the printer off. Then press and hold the "feed" and "pause" buttons while turning on the power. The printer will now be in diagnostic mode - you can page through the menus until it says "ribbon type"
Pick the correct type and press the "pause" key to save the value. Then turn off the printer and turn it on again normally. The ribbon error goes away.
Posted on Mar 21, 2009
Anonymous
SOURCE: what password code does the polaroid pogo printer
Passward is 6000
Posted on Dec 01, 2009
pci4
  • 8 Answers
SOURCE: What does a Polaroid p85igc card printer use for a
The "i"suffix was introduced in around 2005 to try to stop patent infringements on the printer ribbons. They introduced a chip on the spool that feeds back to the printer. The chip has to be the correct coding for the badge of the printer. Zebra P330i printers are essentially the same as Javelin J330i and Polaroid p85igc but have three different part numbers for their YMCKO ribbon. You can run any monochrome ribbon on them because the mono ribbons have no chip.....not much profit for the brand owners. YMCKO however is not interchangeable. Find a Polaroid dealer for the full colour ribbon.
Posted on Dec 15, 2009
Anonymous
SOURCE: hello, my zebra ZM 400 keeps giving me the message
I had it too, and I solved it substituting the firmware.
Bye
Posted on Dec 16, 2009
How do i clean my printer after I change the ink roll?
What does this mean? "ink roller". I''ve never have never heard the term. Does you mean ink ribbon roll? Why would you need to clean anything with that type?
Sep 02, 2014 | Polaroid P3500S Id Card Printer System
My computer doesn't send picture to be printed to my hp photosmart 8450. I have Windows Vista and it worked before. Now why does it show an error in the printer info and also, this printer is set as...
If there is something wrong with the printer, you should get a error message describing the error.
Does the printer have a blinking orange light after you give the print command? Then there is an error in the printer. If you have documents in the print queue, delete them. Remove the printer cable. Shut the printer down, shut the computer down. Reconnect the cable and turn everything on again.
If there is still a problem there might be something wrong with your printer.
If you don't have a blinking light after the print command on the printer, then try changing the printer cable. If not working, try another USB port. If still not working, reinstall the printer.
Sep 21, 2010 | Dell Office Equipment & Supplies
103 service ITU ERROR
lexmark basically has said that if this error doesnt clear by powering off the machine and powering it back on again then it will need to have a service call. this error means there is a problem with the itu belt assembly.below is what they say. the steps were to pwoer it off and back on again using a grounded wall socket
This error normally requires a service call. However, certain rare occurrences, such as a stray static discharge in the vicinity of the printer or a power fluctuation, can cause a false 103 ITU error message to appear. In these cases, the error is only temporary and can be easily resolved without service. Follow the steps in the table.
Step Action 1
Power the printer off, wait ten seconds, and then power the printer back on.
Did the error message return?
Yes: Continue to step 2
No:
Print a test page. If the page prints, the printer is functioning correctly. 2
If possible, connect the printer's power cord directly into a grounded wall outlet. In rare instances, a surge protector or uninterruptible power supply (UPS) can generate false error messages.
Yes: Continue to Contacting Lexmark below.
No: Print a test page. If the page prints, the printer is functioning correctly.
Nov 19, 2009 | Lexmark C760 Laser Printer
Samsung STP-103 Thermal Printer will not print lines correctly
Wow, serial communications still in use. Naturally, both units have to use the exact same protocol N81 for instance, so make certain the sending unit is set to the same, then check the cable to verify that the appropriate pins are connected and or crossed. I believe your symptoms can be caused by using hardware handshake and having pins 6,8,20 (20 only if a 25pin connector) shorted on the printer end. If possible, you can try switching both devices to software handshake.
May 07, 2017 | Samsung BIXOLON® STP-103 Printer
Canon pixmaip4000
Delete Queued Print Job If a print job is corruptand does not print clearly, does not print at all or is preventingother queued jobs from printing, delete the queued job.
  1. On the Windows taskbar, double-click the printer icon located to the left of the time.
  2. At the Printer window, select the print job, under 'Document Name' column, to highlight it.
  3. From the 'Document' menu, select 'Cancel'.
  4. Repeat steps two and three to cancel another print job.
  5. Ifthe print job cannot be cancelled or will not stop printing, shut downthe compuer, disconnect the printer cable and then restart the computer.
    1. Close the Printer window.
    2. Shut down the computer.
    3. Disconnect the printer cable (USB or parallel cable).
    4. Restart the computer.
    5. If a message window appears asking to cancel printing, select 'Yes'.
    6. Verifythe printer icon no longer appears on the Windows taskbar. If the iconappears, double-click it and cancel the remaining print jobs asinstructed on steps two and three.
    7. After all print jobs have been cancelled, reconnect the cable to the printer and then try to print again.
  6. Ifthe print job does not complete, it may be necessary to disconnect theprinter cable, power off and on the printer and then reconnecting thecable.
May 04, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
Dymo 400 labelwriter does not print unless shut down and rebooted
It could be how you have loaded the labels. If you have loaded the labels and there is a small gap between the spindle and the roll, it will print one label and give a error-printer message and stop working until you unplug it for 30 seconds and plug it back in. I would reload the labels from scratch and ensure there is no gap.
Feb 17, 2009 | Dymo LabelWriter 400 Thermal Printer
Printer not communicating with computer
(1) Try a power cycle: Try turning the printer off, then unplug the power supply from the printer, then unplug the USB cable from the printer then the back of the computer; wait 30 second; then plug the USB cable back into the computer, then back into the printer then plug the power supply back into the printer and turn it on – run a test print: Start>Settings>Printers>Right-click on the printer>Properties>Print Test Page
(2) Update the USB drivers
Jan 01, 2009 | Lexmark X5470 All-In-One InkJet Printer
HP Printer will not print!
It is really my first time to encounter that particular message that the "directory needed is unavailable". Here are the things that i want you to check.
1. Make sure that you logon to your computer using the Administrator previlege. That way, it will allow you to install and uninstall programs or softwares without any warnings.
2. Try to open the controlpanel>>> go the Printers and faxes>>> then make sure that the HP Deskjet F300 series has a check mark and it says READY.
3. If it doesnt say ready, right click the printer icon and it will give you option "USE PRINTER ONLINE". click on that.
4. Now, try printing a document.
Note: if the issue still not resolve, please give me further informations about the operating system, when you tried to print does it stays on the printing queue?
Thank you so much
adonscott
Jul 03, 2008 | HP DeskJet F380 All-In-One Printer
Polaroid P3500S Id Card Printer System Logo
74 people viewed this question
Top Polaroid Office Equipment & Supplies Experts
Ekse
Joaquim Martins
Andrew Taylor
Andrew Taylor
Are you a Polaroid Office Equipment and Supply Expert? Answer questions, earn points and help others
