Dishwashers Logo
E
Elizabeth Licudi-Fry Posted on Nov 30, 2018
I have cleaned the filter, added salt and rinse aid, the rotating arm does not appear blocked. I have put a cleaner through the machine however it is still leaving bits! What can I do next please
Zanussi slimeline dishwasher DA4342
5 Related Answers
IFIXALL
Archie Ferrarini
  • 869 Answers
  • Posted on Jun 05, 2008
SOURCE: Not washing properly
This D/W should have been re- called ,toooo many flaws.Sorry!
Anonymous
  • 1239 Answers
  • Posted on Oct 13, 2008
SOURCE: FDW60 Dishwasher
HI
The strainer is located directly under the lower sprayer arm. When the strainer becomes clogged with food and detergent debris, the dishwasher may flood or overfill. On some dishwashers, the strainer is a plastic or metal component consisting of two semicircular halves. To remove this type of strainer, pry it up. On other dishwashers, the strainer is a one-piece component. To remove this type, remove the cap that holds the sprayer arm on its shaft. Then remove the sprayer arm and the strainer.
Wash the strainer in the kitchen sink with water and a mild household detergent. Use a fairly stiff brush to get all the debris out of the holes and slots in the strainer. Rinse the strainer well and replace it. If part of the strainer lifts out for regular cleaning, check it and clean it -- if necessary -- after each load of dishes is washed.
Ambari
  • 901 Answers
  • Posted on May 21, 2010
SOURCE: Filters clean, arms unblocked, salt and rinse-aid ...
Yes! you are already having the answer. check your water inlet flow. Clean the strainer at the machine water hose connecting end.
Check the drain filter also. Refer user guide for instructions on cleaning.
Anonymous
  • 3006 Answers
  • Posted on Aug 16, 2010
SOURCE: my bosch dishwasher has suddenly
You can experiment with different tablets/powders and check that the salt and rinse aid dispensers are correctly adjusted, but all dishwashers eventually cause glass to go cloudy and although it's a gradual process there's a point at which it suddenly seems to become noticeable. Any lead crystal glass will cloud very quickly indeed so must be handwashed if you want to avoid this. The cloudiness in glass is irreversible as it's caused by millions of microscopic cracks in the glass surface. Some crockery items are glazed with a process which can also turn cloudy over time in a dishwasher, white plates won't really show it but coloured ones do (especially blue and red). There are some tablets/powders which claim to have a glass protection additive, but this just slows down the process. The best way to slow the process is to wash at the lowest temperature you can.
HansPP
Hans Pearson
  • 2510 Answers
  • Posted on Feb 13, 2011
SOURCE: I Have a candy dishwasher about 4 years old after
The problem is most likely that there is still water residue at the bottom of your machine. If the machine is not fully drained it picks up some of the residue and sprays that onto the dishes during the final rinse, leaving an unhealthy and unsightly film on everything.
Remove the bottom strainers and make sure that there is nothing obstructing the outlet pipe and the pump. If possible back flush through the outlet pipe and try draining the machine again before using it again.
Rinse solution on Fisher&Paykel dish washer not being used
Problem Possible Cause What to do Dishwasher will not start. No power. Ensure the dishwasher is plugged in and the power supply is turned on at the wall. The door is not properly closed. Close the door. Start/Pause button has not been pressed. Press the Start/Pause button . Water tap not turned on. Ensure water is connected and turned on. Blocked strainer in water inlet hose. Check the strainer and clean if necessary-it is located where the water inlet hose screws into the tap. Keylock is activated. Cancel Keylock by pressing and holding until the keylock indicator goes out. Lower spray arm rotates with difficulty. Spray arm holes are blocked by small items or food particles. Clean the spray arm. See 'Care and cleaning' for instructions. Cover of detergent dispenser cannot be closed. Detergent compartment has been overfilled. Remove detergent until the cover can be closed. Detergent dispenser is clogged with remnants of detergent. Wipe dispenser out with a damp cloth. Dry the dispenser before adding detergent. Remnants of detergent stuck inside dispenser. Compartment was damp when filled with detergent. Wipe dispenser out with a damp cloth. Dry the dispenser before adding detergent. Buttons beep and do not respond. Keylock is activated. Cancel Keylock by pressing and holding until the keylock indicator goes out. Water remains inside dishwasher after wash has ended. Drain hose is crimped, bent, or blocked. Check the drain hose and straighten if needed. Pump is jammed. Call your Fisher & Paykel Authorised Service Centre or Customer Care. Filter(s) blocked. Clean the filter(s). See 'Care and cleaning' for instructions. Foaming. Incorrect amount or type of detergent used. See section 'Adding detergent' or consult the detergent manufacturer's instructions. Too much egg in the wash load. Increase the amount of detergent. Rinse aid dosage level too high. Decrease the rinse aid dosage. Rinse aid spills not wiped up. Ensure that all rinse aid spills are wiped up when they occur. Water tap not turned on. Ensure water is connected and turned on. The dishwasher stops suddenly during the wash. Power or water supply has been interrupted. Check the power and water supplies. Knocking or rattling sound during wash. Spray arm knocking against dishes. Pause the wash and rearrange dishes. See sections 'CH and CHP models - Controls and starting a wash' or 'CK models - Controls and starting a wash', and 'Loading'. Dishes have been stacked incorrectly. Unclean dishes. Wash programme unsuitable for load. See section 'Wash programmes and detergent quantities' and select a suitable programme. Soils were too heavily baked on. Dishes may need soaking. Spray arm(s) unable to rotate. Ensure no items are obstructing the spray arm path. Dishwasher overloaded or incorrectly loaded. See the 'Loading' section. The filters are incorrectly inserted. See section 'Care and cleaning'. Detergent put in the wrong compartment. See sections 'Wash programmes and detergent quantities' and 'Adding detergent'. Excessive food not removed from dishes before loading. Scrape all food scraps off dishes before loading. Unsuitable detergent. Only use powdered or tablet detergent designed for domestic dishwashers. Not enough detergent. See 'Wash programmes and detergent quantities' for recommended quantities. You may need to adjust these to suit your particular load and the hardness of your water supply. Spray arm holes are blocked. Clean the spray arm(s). See 'Care and cleaning' for instructions. The filters are blocked. Clean the filters. See 'Care and cleaning' for instructions. Plastic items are discoloured (e.g. stain left by tomato sauce). Not enough detergent, not pre-rinsed. Pre-rinse plastic dishes before placing in the dishwasher and/or add more detergent. Alternatively, using the Rinse programme after adding dishes may minimise staining. Display flashing while Keylock is on. This is normal. The display remains on although the buttons are disabled. No action required. White stains are left on dishes; glasses have a milky appearance. Not enough detergent. See section 'Wash programmes and detergent quantities' for recommended quantities. You may need to adjust these to suit the hardness of your water supply. Rinse aid dosage too low. Increase rinse aid dosage. See 'Using rinse aid'. Dishes, cutlery have not dried. Rinse aid dosage too low. Increase rinse aid dosage. See 'Using rinse aid'. Items removed too soon. After the end of the wash programme, leave the door ajar and wait for several minutes to help drying. Rinse aid dispenser empty. (The rinse aid indicators are lit.) Add rinse aid. See section 'Using rinse aid' for instructions. Glasses have dull appearance. Rinse aid dosage too low. Increase rinse aid dosage. See 'Using rinse aid'. Tea stains or traces of lipstick have not been completely removed. Not enough detergent. See section 'Wash programmes and detergent quantities' for recommended quantities. You may need to adjust these to suit your particular load. Wash temperature too low. Select a wash programme with a higher temperature (see section 'Wash programme data' for information). Traces of rust on cutlery. Cutlery is not sufficiently rustproof. Wash by hand. Glasses clouded and discoloured; milky coating Hard water situation. Increase detergent quantities. Glasses are not dishwasher proof. Wash by hand. Water marks left on glasses and cutlery. Rinse aid level or dosage setting is too low. Ensure there is rinse aid in dispenser. If necessary, increase the rinse aid setting or try using a wash programme with a higher temperature. See sections 'Using rinse aid' and 'Wash programme data'.
Nov 12, 2018 • Dishwashers
Dirty glasses dishwasher
1st thing is make sure the dishwasher is heating up the water.
if it is heating... you spray arms may be blocked up with food particals.
Dishwasher salt beko
Rinse aid and salt are not necessary if you use powder that is similar to the tablets. The lights are warning you that you havent added them, you know that so ignore the lights. If you live in a hard-water (limescale) area salt can be used as well as tablets or powder to make the water kinder to the machine, but most people just use tablets without rinse-aid or salt.
Dec 14, 2013 • Dishwashers
Dishes in upper rack have a white deposit on them. Some glassware can be cleaned by hand, but not entirely (as if they are etched). I am using rinse aid and have checked/cleaned the filters. Unit is a...
Check your salt container is full and the cap is on securely and there are no cracks in lid. Check the water hardness setting for your supply is correct. Check the rinse aid is full and the rinse aid function is turned on according to the user instructions. Ensure that the items being washed are d/w safe. Check that the holes in the spray arms are not blocked with food, plastic etc. or if you have a deodoriser hanging on the top basket that it is not obstructing the rotation of the spray arm. Try running a d/w cleaner through the machine.
You can remove 165263, see link.(remove t20 screw via the sump after all filters are removeds) this will expose the pump impellor and you can check for any obstruction. If the d/w is connected via a sealed spigot to the sink, remove the grey hose and unscrew the spigot adaptor from the sink and ensure there are no blockages. Some items, particularly glass are best washed on a lower temp cycle and for inproved results use a detergent that incorporates a glass protection component.
https://www.bosch-eshop.com/eshop(bD1lbiZjPTAwOQ==)/bosch/gb/prodp.htm?prod=SHU6802UC%2f12&ESHOPTYPE=S
ps I appreciate the link is not for your model but the part placing should be the same
Hope this helps, please leave feedback or add comment if this helps or you require further assistance.
May 19, 2010 • Dishwashers
Hello. My dishwasher has been pretty perfect for four years. When my house water softener ran out of salt, I added rinse aid and salt to the dishwasher for the first time. I subsequently added salt to the...
Try cleaning the machine by adding white vinegar to the wash water (before the water-fill procedure finishes). Put your stained dishes and cutlery in with the wash to remove the hard water deposits. The combination of salt and rinse aid may have helped cause this problem. Hope this helps!
Feb 11, 2010 • Dishwashers
1helpful
Hotpoint Aquarius DF61 Dishwasher & Food residue remaining
i have cleaned the filter on my hotpoint aquarius DF61 on cant put it back together.
Nov 17, 2008 • Dishwashers
Top Zanussi Dishwashers Experts
Mike Cairns
Mike Cairns
Paul Carew
Renee Knafel-Bullock
Are you a Zanussi Dishwasher Expert? Answer questions, earn points and help others
