SOURCE: download manual for coby tf-dvd7100
Go to www.cobyusa.com
Click on Support.
Go to FAQ's.
Under DVD's, click on the question that gives you the PDF of the manual.
It's about 24 pages in length.
SOURCE: Coby DVD shows Invalid Disc HELP PLEASE
Did you make the disk if you made the disk your computer has to give it a digital signature so the DVD player can read it if you're using a regular DVD then I would very carefully using rubbing alcohol and Q tip clean the actual laser I would be very careful doing this if too much rubbing alcohol is on the Q tip it will ruin the laser you can also try resetting the DVD player by taking out the battery and unplugging it from any power source and leave it that way for at least 20 seconds to a minute if that doesn't work you might have something else wrong
SOURCE: I'm looking for an optical len for my coby dvdplayer TF-DVD7100
You can try www.partstore.com if they do not have it they can order it for you. thanks
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
SOURCE: manual for coby portable dvd player
http://www.retrevo.com/s/Coby-TF-DVD7005-Portable-DVD-Players-review-manual/id/286ag025/t/1-2/
Manual is above.I hope i helped.
