COPIER WAS PURCHASED NEW IN JULY 2017 AND HAS 62,543 COPIES ON IT. COLOR PRINT AND COPIES ARE GHOSTING EXCEPT IF YOU PRINT FROM THE INTERNAL COPIER PRINT OUTS.BLACK OK INTERNAL STATUS PAGE PRINT OUT GOOD. STOPPED COPY IN MIDDLE OF RUN AND GHOSTING WAS ON THE TRANSFER BELT ELIMINATING THE FUSER. REPLACED THE TRANSFER BELT SAME PROBLEM.
SOURCE: kodak 5100 no black printing, light on colors
Had the same issue... No black ink. Called the # from "Solution #1" guest, 18004216699. Had to patiently go through all the basic trouble shooting stuff like calibration, print head clean, demo print, etc. Once I went through that, they issued me a new print head for free, no shipping charges or anything. Just did this today, but they say I should have the print head in 3 days.
For once, service worked like it should!
SOURCE: Print faded after replacing black cartridge Brother 240C
The print heads don't appreciate being out of ink so the Brother printer has sensors to prevent that but the tape defeated that prevention. Maybe more cleanings or maybe a cartridge with printhead cleaning solution will help. Otherwise, I fear a new printer.
SOURCE: Printing black line down middle of page when coping
The fuser is located in the back of the printer. I think it's held in by to screws. It's about hte same size as the toner cartridge. Please visit these websites.
This is the fuser kit.
http://store.printerprinciple.com/products/rm1-3044
The service repair manual.
http://www.scribd.com/doc/15253671/HP-Laserjet-3055-Repair-Manual
Fuser Replacement is on page 170.
SOURCE: Oki C5500 printer has ghosting on most of the
This type of print problem associated with laser printers is due to the corono wire needing to be changed. The wire is not fully pulling the toner off of the drum completely. If you can access it, cleaning it may help (usually a lever that you are supposed to run back and forth a few times that wipes the corona wire). If the cleaning doesn't help, then it probably needs replacing.
