HP Officejet Pro L7780 All-In-One InkJet Printer Logo
Posted on Aug 04, 2009
HKLM\SYSTEM\CurrentControlSet\Enum I am trying to instal HP 7780 All in one but I get error no registry key and:HKLM\SYSTEM\CurrentControlSet\Enum Does any one had such a problem?
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Sep 01, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
4126
Points
12
I've got this problem and HP ask me to press CRTL+SHIFT and cancel. So the instalation keep going normally till the end. This was a SP3 update and some machines with WXP Home could happens.
Regards,
Marcelo
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Aug 06, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
4126
Points
5
COPY CD to DISK
edit autorun.inf
change BlockIfFail=Yes to BlockIfFail=No
and run setup.exe
luciano
Anonymous
Level 1:
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
4126
Points
5
COPY CD to DISK
edit autorun.inf
[email protected]
Anonymous
Level 1:
  • Contributor 32 Answers
  • Posted on Aug 04, 2009
Anonymous
Contributor
Level 1:
Answers
32
Questions
0
Helped
13834
Points
38
well i just watch your problem,
you are saying that I get error no registry key and:HKLM\SYSTEM\CurrentControlSet\Enum.
This problem is related to operating system,
So you please install your printer on other computer by CD.
Cant get it to install
uninstall the existing printer drivers first before you try a reinstall.
tip
How to fix Blank Device manager
RESOLUTION:
CREATE A RESTORE POINT BEFORE ANY OF THESE STEPS
STEP 1:
Check if Plug and Play service is started.Check the settings of the same in the
registry
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\PlugPlay
ImagePath = %SystemRoot%\system32\services.exe
ObjectName = LocalSystem
PlugPlayServiceType = 3
Start = 2
Type = 20
STEP 2:
Advanced cleanboot (316434) and Hardware cleanboot (SOX051008700004)
STEP 3:
System restore (306084)
If we know when the issue started, read the system restore point information for
that day prior to trying the restore
STEP 4:
Look for the update KB905749 and try uninstalling it. Be sure to shut the system
down and wait 10 seconds before restarting.
STEP 5:
Go to safe mode - check for bangs in hidden devices in System devices - Uninstall
PnP BIOS Extension and any other device having a bang
STEP 6:
- Follow SOX041029700032
check the permissions on
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Enum
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Enum\Root
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Enum\Root\LEGACY_RASAUTO
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Enum\Root\LEGACY_RASAUTO\0000
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Enum\Root\LEGACY_RASAUTO\0000\Control
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Enum\Root\LEGACY_RASMAN
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Enum\Root\LEGACY_RASMAN\0000
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Enum\Root\LEGACY_RASMAN\0000\Control
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Enum\Root\LEGACY_TAPISRV
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Enum\Root\LEGACY_TAPISRV\0000
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Enum\Root\LEGACY_TAPISRV\0000\Control
If Administrators is listed, then remove Administrators. The default permissions
for these keys are:
System : Full Control : This key and subkeys
Everyone : Read Only : This key and subkeys
Change the permissions so that they apply to "This key and subkeys" and not just
"This key only".
STEP 7:
We could try to register the following files
regsvr32 devmgr.dll
regsvr32 dmocx.dll
If the files are missing, extract a copy from Windows XP CD-ROM or the
ServicePackFiles folder
STEP 8:
Copy the following on a notepad.Save it as dev.reg.Double click on the same.Restart
the computer.
on May 03, 2010 • Computers & Internet
I got this computer from my grandmother because myn melted literally. But she downloaded k9 web protection and had it on the highest security setting there is.it only allows facebook and certain other...
I found this on superuser link at the bottom.
No third party software required. Tested with K9 Web Protection version 4.4.268 on Windows Vista SP2 (32-bit). Confirmed by @stiemannkj1 to be working on Windows 7. Should also work on Windows 8.x.
  1. Create a new text file. Copy and paste the following batch script code, then save:@echo off set keys=^ "HKLM\SOFTWARE\Blue Coat Systems"^ "HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\App Paths\k9filter.exe"^ "HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Blue Coat K9 Web Protection"^ "HKLM\SYSTEM\CurrentControlSet\Services\bckd"^ "HKLM\SYSTEM\CurrentControlSet\Services\bckwfs" REM remove registry keys for %%G in (%keys%) do reg delete "%%~G" /f >nul set folders=^ "%programfiles%\Blue Coat K9 Web Protection"^ "%programdata%\Microsoft\Windows\Start Menu\Programs\Blue Coat K9 Web Protection" REM remove folders for %%G in (%folders%) do rd /s /q "%%~G" set files=^ "%windir%\System32\drivers\bckd.sys" REM remove files for %%G in (%files%) do del "%%~G" pause exit /b
  2. Make sure file extensions are shown and rename it to RemoveK9.cmd (or whatever you like, as long as it has the .cmd extension).
  3. Restart Windows in Safe Mode.
  4. Right-click the .cmd file and select Run as administrator from the context menu. Wait for the batch script to finish.
  5. Start regedit.exe and navigate to the following registry key:
    <code>HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Enum\Root\LEGACY_BCKD Right-click the LEGACY_BCKD key and select Permissions from the context menu. Click Advanced and select the Owner tab. Then select Administrators from the owner list, tick the Replace owner on subcontainers and objects option, and then click OK. Then select Everyone and tick the Allow checkbox for the Full Control permission. Click OK, right-click the key and finally choose Delete.
  6. Restart Windows.
How can uninstall K9 Web Protection without K9 admin password
1helpful
Errors
solution 1>
CAUSE:
Certain HP services (and associated DLL files) were somehow partially/improperly installed. (Possibly, from a previous failed install?)
The Windows services (files) were:
Pml Driver HPZ12 (C:\Windows\System32\HPZipm12.dll)
Net Driver HPZ12 (C:\Windows\System32\HPZinw12.dll)
The existence of these 2 files in the System32 directory was causing this error in my situation. Somehow, the installation script was not identifying that these files were already installed (or improperly installed) and failing to properly set them to be installed again.
SOLUTION:
Steps:
1) Check to make sure that the 2 Windows services above are not running (or not installed).
2) Rename/delete the 2 associated service DLL files (this will only be possible once the services are stopped)
3) Run the installation again.
solution 2>
complete uninstall printer software from computer.
run uninstall L1 L2 L3 L4(if not an hp computer).
run same uninstall l1l2l3l4 from 7z..folder or hp folder from temp if availalbe.
then clean from add remove programs/program and features.
then clean from cleanup utility all hp pritner related entries.
then clean temp folder. clean recycle bin.
delete c:\program files\hp and hewlett packard folders (if not an hp computer). on hp computer delete digital imaging bin folders.
delete following folders from following locations-
C:\windows\System32\Spool\Printers and deleted entries inside it
C:\windows\System32\Spool\drivers\w32x86\*.* deleted entries inside it
C:\windows\twain_32.
cleanup from regsitry--
plz make back up for registry first.
>> hklm/system/current control set/control/print/environment/windowsNT(x86/64)/drivers + processors delete all pritner entries from there.
>> hklm/system/current control set/enum/usb/vid_000,vid_003 delete.
>> hklm/system/current control set/enum/usbprint delete pritner entries.
>> hklm/system/current control set/control/print/monitors/hp standard tcp/ip ports/ports.
>> hklm/system/current control set/control/print/monitors/standard tcp/ip ports/ports.
>> delete same ports from printers and faxes/pritners pritner properties ports
>> hklm/system/current control set/control/print/monitors/hpz..
>> hklm/system/current control set/control/print/providers/lan man settings.
>> hklm/SYSTEM/CURRENTCONTROLSET/CONTROL/PRINt/PRINTERS
>> hkey_Current_User\Software\Hewlett-Packard
>> hKey_Local_Machine\Software\Hewlett-Packard
>> HKEY_USERS\.DEFAULT\Software\Hewlett-Packard
>> hkey_current_user\software\hewlett packard delete if not hp computer.
>> hkey_curent_configuration/system/current control set/control/print/pritners.
then go to msconfig
make it selective startup disable all microsoft services except hp services. hide all microsoft services. disable all startup tab apply restart.
after restart install cue version 12 officejet pro 8500 or 6500.
then run msiexec.exe /unregister then msiexec.exe /regserver cmd commands.
then install software from downloaded version of original pritner install only basic drivers first and imaging devices only and use solution center 12. cue 12.
issue resolved.
2answers
J6480 fatal error 2753 MSI.dot4wrp during full driver install. I tried uninstalling al related hp drivers, all the HP advice. Disabled firewall, services etc. Do you have a solution that works?
you can try with installing the windows installer 4.5 and then try.. otherwise reinstalling windows might work because the error you are getting is related to installer.. and its a service of windows itself which is responsible for all the software installation..
1helpful
3answers
Failed Error During Installation. MSI.dot4wrp...Error Code 2753' Message Displays on the Computer in Windows XP and Vista
This is an internal installation error. There can be 2 solutions:---- Solution 1:-- Find all of the hpqwrg files and delete them before installing the software:
  1. Click Start .
  2. Click Search ( Find for Windows 98).
  3. Click Files and Folders .
  4. In the Named entry box, type hpqwrg .
  5. Set the Look In entry box to C: .
  6. Click Search Now ( Find Now for Windows 98).
  7. Click Edit , and scroll to Select All .
  8. Delete all files pertaining to hpqwrg . There will be approximately five to six files.
  9. Be sure to empty the recycle bin of these files also.Solution 2:---- Completely uninstall the higher version of software and reinstall the lower version first, follow the steps below in order:
    1. Uninstall all of the HP Photo and Imaging software (for both of the products). (The uninstall program can be found in theControl Panel in Add/Remove Programs ).
    2. Re-install the lower version of the software.
    3. Re-install the higher version of the software. Thank you Sir.
7helpful
Error Code: 2753 " Fatal Error or error MSI.dot4msi"
CAUSE:
SOLUTION:
Steps:
solution 2>
then go to msconfig
issue resolved.
1helpful
3answers
I can not install my HP Printers Officejet-- gives fatal error
This issue requires some serious trouble shooting and solutions cannot be posted as they are too long.
If you want further support you can avail free technical support on http://tinyurl.com/m7ghqz
3helpful
Help with HP Deskjet D1560 Printer!!
Solution 1
Right click on setup file and select run as administrator
Solution 2
  • open registry editor, start -> run -> type in: regedit
  • Open Hkey_local_machine folder
  • Open System folder
  • Open Currentcontrolset
  • Right click with mouse on enum
  • Select Permissions
  • make sure user: SYSTEM has FULL CONTROL permission
  • See picture:
Make sure system has Check On Allow Full control and read.
Check all users listed that there are no checks on deny.
You can also press ADD to add your own user, then click advanced, then click find now , select your user, click ok, click ok, give your
user full control and read permission.
Apply and ok. double check that there are no Deny permissions set.
let me know the results and do not rate solution untill we have solved the problem.
Thanks,
Ekse
HP Deskjet D2360
First, try running the installation as Administrator. Right click on the executable and select Run as Administrator. If that doesn't work, go to that registry entry and make sure that System and Administrators have Full Permissions.
k24674
Grand Canyon Tech
Grand Canyon Tech
