Some of to much compression or there is a mistake for oil/diesel in gasoline problem or oil came into cilinder by turn a circular mower too the wrong side to mount or replace the rotary blade , always with the exhaust/muffler up where the valves are by wrong side there comes some oil into the cilinder by valve that will give to much compression (octanenumber) and kick back in the early time ,or fill too much oil could be possible .
Bring back the right oil level and replace the gasoline if neccesary
I remove the oil and rotate the engine and same thing turn hard to pull the rewind starter
the oil level in the carter must be on a normal oil level and use of a good 4stroke gasoline for the snowblower ( not 2 stroke ) then it must become better after short use if not there is something wrong by the valves
SOURCE: Husqvarna Chain Saw Rope Pulls Very Hard, what is the cause?????????
Has it always done this or has it developed?
Some saws have a decompression button to make it easier to pull over.
SOURCE: poulan starter rope
to fix starter rope first you must wind spring and place back in housing. just grab spring by middle and wind ,you will have to get it smaller than housing hole. One end should hook to a tab at housing rest of it sets inside itself. once set in housing dont let go, insert rope housing over top & screw in. rope housing should have some return spring to it when pulled. if rope is not tight on return pull simply add one winding to spool. hope it helps!
SOURCE: Starter rope too hard to pull on Yard Machine By MTD
Not sure if this will help. Don't want to sound like a **** but....Have you made sure nothing is caught or jammed inside it. This could make it hard to start with the cord..
SOURCE: starter rope will not pull. Will pull smoothly
If I understand what you are saying... The starter pulls smoothly with the starter cover removed or when installed and the plug removed (no compression or spark). If this is correct I think your saw's timing has slipped or maybe a defective decomp valve. Time to visit your neighborhood chainsaw seller/mechanic.HTH
Lou
Testimonial: "cheers"
SOURCE: Reinstall the starter rope on a Homelite Model UT 08026 J.
Go to smalleng.com free video for just what you are experiencing.
