I have that organ (trying to sell it on Craigslist) and have the manual. I can make a copy of it and mail it to you. Cost would be $10. Here is the Craigslilst link, where you can see a picture of the manual.. Baldwin MCX 1500 Electronic Organ Digital Keyboard Orchestra
Try the organforum . com. There are a lot of Hammond people there. The model 700 is the base model and probably enough to get you started.
Also just get a organ music book as a lot of the vernacular is in those. Also check your library for organ books. OFTEN the user manuals aren't much use to learn the instrument.
Most organs will either have tabs or drawbars. These select the type of "voice" and often one selects more than one as a mix. Each keyboard is refered to as a "Manual". Most organs have foot pedals. Each of the manuals and the foot pedals will have a seperate set of tabs associated with them.
To get started, turn on the organ and press the expression pedal which controls the volume... experiment setting a few tabs or drawbars an play notes on the manuals. You will soon learn what controls what.
Note that some models of Hammond organs used rotating tone wheels and those require lubrication. Those that do, usually have a power switch labelled "start" and "Run". These organs are usually higher value and one should have them serviced before using.
A Leslie is special speaker system that is spun to break up the sound so it doesn't seem to come from a single point.
Sometimes the Leslie speaker is in a seperate cabinet fromthe organ, and SOMETIMES it is a simulated Leslie that is done with multiple speakers and electronic switching. If the Leslie is an external one, it usually attaches via a cable that often has either 9, 11, or 13 pins.
