Heating & Cooling Logo
R
Ronald Posted on Nov 27, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a red stone propane heater and the pilot light will not stay on
Donni Steen
Level 3:
  • Master 687 Answers
  • Posted on Nov 29, 2018
Donni Steen
Master
Level 3:
Answers
687
Questions
0
Helped
446632
Points
2142
Make sure that the flame sensor is clean. You can clean them with emory cloth. If it continues, then the flame sensor will need to be replaced. There could also be a problem with the thermal lockout, which means the circuit is stuck closed. It's a safety switch that is designed as a protection from fire if it overheats. Hope this answers your question. Good luck.
john h
Level 3:
Top Expert:
  • Heating & Co... Master 29,494 Answers
  • Posted on Nov 28, 2018
john h
Level 3:
Top Expert:
Answers
29494
Questions
0
Helped
7559424
Points
193449
Check the thermocouple
5 Related Answers
Anonymous
  • 148 Answers
  • Posted on May 12, 2009
SOURCE: pilotlight will not light, getting spark, but no propane.
make sure you have the gas valve knob on turned to pilot while pressing that down while pushing the spark it should light or it is tripped on a safety like rollout switch or oxygen depletion sensor if equipped which all ventless heaters are
Anonymous
  • 149 Answers
  • Posted on Aug 09, 2009
SOURCE: Laars Lite 2 LG - pilot light will not stay lit.
It sounds like a thermocouple has gone bad. this is a very common problem with gas powered things ie; water heaters, furnaces, hot tubs. The telltale sign is when you release the pilot light button it won't stay lit. This is a safety feature and is relatively inexpensive and easy to repair.
Anonymous
  • 139 Answers
  • Posted on Sep 16, 2009
SOURCE: Have Model CGP30TB Copmfort Glow propane
sounds like an obstruction in pilot assembly.try using canned compressed air to blow directly into pilot. this technique is successful about 70%. if not,pilot assembly must be removed and cleaned thorougly
Anonymous
  • Posted on Jan 21, 2010
SOURCE: COMFORT GLOW PROPANE HEATER, THE PILOT LIGHT WILL NOT IGNITE
i vacuumed the line out, i taped the angle adapterso there was only a little bit showing and stuck it on the pilot hole for 3 minutes (I turned the gas off) and it fixed it
Anonymous
  • 77 Answers
  • Posted on Jan 22, 2010
SOURCE: dyna glo tag along propane heater pilot stays on but when turning
sounds like either a bad thermocouple or more likely a pressure regulator problem. should have unit checked by someone familiar with propane systems.
I have a nexgrill propane patio heater the pilot light works but when i turn it to lo or high after a minute or so the pilot light stays on but the burner wont light
Propane Patio Heater Troubleshooting - YouTube
? 6:54
www.youtube.com/watch?v=BqYIWuDUZOUDec 12, 2008 - Uploaded by PatioShoppers Great tips about troubleshooting your outdoor patio heater. ...Pilot Light Won't Stay Lit - How to Replace a Broken Thermo Couple on Furnace ...
I have a new red stone gas heater was workin good now the pilot wont stay lit
is there an 800 number for parts...mine is a (Red Stone vent-less natural gas heater)
1helpful
I have a Mr Heater infra red propane wall heater. My problem is it turns itself off (pilot light) after running for an hour or two. I have no problem getting it turned back on but for some reason it d
Your pilot flame should be blue with a small yellow tip, and it should cover the thermocouple (a small rod in front of the pilot light). If the flame is too small and doesn't cover the thermocouple, it may be adjusted too low, or you have low gas pressure or you have a leak in your gas line coming in to the heater. If the flame looks like a lazy yellow flame, you are probably not getting enough air to the flame. Check that your air openings around the pilot are not clogged up. If the flame looks like a waving blue flame then you probably have excessive draft at the pilot. If the pilot flame looks good and covers the thermocouple, then the thermocouple might be bad. Best of luck. I hope I have helped.
Pilot light wont stay lit after you release the knob
clean pilot first ,check thermocouple is tight , you may need to change it
Have a Reddy Heater RCP275 propane gas heater. If able to light - the heater will burn for 1-5 min. but then goes out. Sometimes burner will not light at all when the red pilot button is released. At times...
Sounds like the igniter needs to be replaced. It is normal for a heater to run five or so minutes that means the thermostat is working. then restart when the temp calls for heat but if the igniter does not work it will not light up again.
4helpful
2answers
Laars Lite 2 LG - pilot light will not stay lit. As long as you hold down the pilot light once it is lit it stays lit but when I turn the nob to the "on" position (release the pilot light button) the flame...
1helpful
Water heater will not stay lit even after replacing thermal coupl
The pilot must encompass the thermocouple "bulb" in order for the thermocouple to generate enough current to keep the pilot valve on. You must also hold the red button down for a long enough period to get the thermocouple hot. If the pilot is not large enough, it could be due to a clog in the pilot orifice at the pilot itself. Sometimes a couple of passes over the end of it with fine steel wool is all it takes to clear it.
Hope this helps. Feel free to share what you found. Thanks.
1helpful
I have a propane reddi heater and I can't get it to stay on after I light it, it won't stay on. Is there something that needs to be cleaned or replaced
Generally speaking a propane heater stays lite because the pilot stays lite. The pilot flame touches a thermocouple which produces a current which keeps the main valve open. Pilot goes out or you have a bad thermocouple or the pilot is slightly clogged (reduced heat to thermocouple) or maybe the thermocouple is not touching the flame enough. Most times when a propane heater goes out the problem is somewhere in that neighborhood. Thermocouple - pilot. I have always had luck carefully taking those parts off, cleaning, and reassembling, but check the position of the thermocouple first. Looks like a small brass rod which sticks into the flame. This is a safety mechanism to prevent the flame being blown out and leaving the gas on. Good luck
New heater pilot will not stay lit
gas and fire, I would return it before you blow something up.
Top Heating & Cooling Experts
Paul Carew
john h
