Take model # to searspartsdirect.com. They typically have manuals in parts listings.
Possibly a similar model has procedure to set time on page 5.
I did not see your model you provided, except as a radio. Perhaps there is another model number.
https://www.manualslib.com/manual/59333/Ge-Spacemaker-7-5400.html?page=5#manual
Https://www.geappliances.com 1-800-433-2682
SOURCE: GE SPACEMAKER XL MICROWAVE OVEN JVM1440
Assuming that your internal cooling fan is working, I would suspect that your magnetron is failing.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There
should also be a "mini-manual" hidden inside the unit behind the
control panel or hidden on the
left side behind the grille, which is
very helpful when troubleshooting, testing, and locating components.
I would check the cooling fan, then suspect the magnetron.
SOURCE: bulb replacement
NO,If you can get to the three phillips screws directly over the vent door then you do not have to take the unit down. Unplug the unit. Remove the top three screws over the center of the louvre and then carefully lower the vent louvre. (Lowering helps me get a better grip on the louvre assembly. Then you will slide the vent louvre assembly about 1/8" to the left and then it will pull straight back and out. In the center is an aluminum cover which has a phillips screw facing you. Remove this screw and the cover plate. The light bulb is directly to the left of the inside of the cover plate. You will see the metal tabs which hold it in place. Pull the bulb housing assembly straight out (to your right) as you face the microwave. Then you will locate your halogen 120V 20W bulb. I just received this from a fellow guest on fix it and I was able to fix my unit 10 mintes ago.Also another tip was to take the inside glass out when reinserting the bulb unit back in because it does get in the way. Good Luck
SOURCE: GE SPACEMAKER XL1800 MODEL: JVM1860BF001
MAGNETRON, 99% of the time with your complaint
Testimonial: "thanks. I just hate to replace whole unit but it looks like it is going to cost 125 for magentron and 100 for service call plus. "
SOURCE: F3 error GE Spacemaker XL 1800: Model JVM1851CD.
F3 on a GE / Hotpoint
microwave means you have a shorted membrane keypad (aka membrane switch).
If and when an oven is coming on or doing anything by
itself, this is very dangerous and can result in a fire.
So until it is repaired,
please leave it unplugged or leave the door
open when it's not in use, and of course one should never leave a microwave unattended while cooking.
If you (or someone you
know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically
involved.
You can find
model number here.
There
should be a "mini-manual" (tech sheet) hidden inside the unit
behind the
control panel or hidden on the left side behind the grille, which is
components.
If you would like to
have us
do this repair for you, we do that for $39.95 plus part costs nationwide.
Either way, we can let
you know what your options and costs would be and send you other
helpful info.
At
our Web site, we have a video
available showing how to remove a typical
over the range control panel assembly in under 5 minutes.
Feel free to contact me directly (and please remind me of your
full model number from the tag on the unit) for more
information & help.
We're
William E. Miller, AS-EET
[email protected]
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
SOURCE: I have a GE Spacemaker model #JVM1650CH01 that
my spacemaker xl jvm 1650 microwave shuts down after just a few minutes of operation and after a few minutes needs to have a clock/time/day etc reset. is this reparable by a homeowner?
GE Spacemaker Kitchen Under Cabinet 7-4290C AM FM Radio CD Player Light Mounting. How do I set the clock
