SOURCE: ruffler for viking 1050
The available ruffler is a generic part. But, it is made for most Low Shank machines. ANd no, you can not change the shank from high to low. Doing that or attempting to do that will not allow the needle to go all the way down as it would set for a high shank.
SOURCE: Is this machine a high or low shank?
High Shank Machines are all the Janome Embroidery models MC 8000, MC 9000, 10000, 10001, 11000, 200E, 300E, 350E....etc
If yours is not an embroidery machine, it has a LOW SHANK .....the higher shank allows for easier access for the embroidery hoop.
SOURCE: Need instructions for putting a walking foot together
http://www.husqvarnaviking.com/us/2821_3079.htm
This is a link to husqvarna site for help..Hope this can help you. Wayne
SOURCE: presser foot control -- Viking Husqvarna #1 sewing machine
There is a presser foot pressure dial on the left end of the machine, make sure it is on 3 or higher.
Testimonial: "Thanks--Don't know how the wheel was moved, but that fixed the problem. Now if I could only find the owner's manual!! "
SOURCE: I bought a walking foot
I think it depends on your shank and everything I see on your model says low shank not high. I would double check that, a vertical is one that the bobbin does not just drop in, you open the front & take out the case and put your bobbin in and a horizontal is the one that you just open the the plastic slide on top of your machine and put it in. Take your manual in with you to Sears and let them help you get the right one.
