This is the plate that fits ontop of the skimmer basket when vacuuming the pool manually. turn off main drain valve
SOURCE: kenmore vacuum model 37105 no suction
are the brushes moving?if so , it is clogged somewhere, that is my guess
Have you checked the floor head? Use a pipe cleaner or twisted metal to carefully and gently see what's in there. It sounds like dirt or something has definately sealed up the main suction channel.
SOURCE: Getting suction to use attachments
got a kenmore progressive dierect drive bagless .it makes a alful noise and the dirt light stays off doesn't pickup
SOURCE: Our Zodiak G4 pool cleaner is not pulsating. We
If the cleaner is not pulsating then either you don't have enough suction or the diaphragm is bad or clogged. (if you have WAY WAY too much suction the diaphragm can stuck collapsed, or a hose can crimp. this will also cause it to stop pulsating.) It is very common to have a **** or tear next to or just below the plastic retaining ring that holds the diaphragm on the inner cassette tube. Also check and make sure there are no holes or breaks on the hoses. When you check the suction with the pool pulse, make sure suction not too high or too low. If the suction is too high it will usually pulse very very rapidly, but sometimes the diaphragm can get stuck as mentioned above. If you have proper suction, and the diaphragm is fine then it will pulse. the only other possible problem is the the cassette assembly could be damaged, or cracked. Hope this helps. If you need further assistance post a reply in the comments, and don't hesitate to leave good thumb rating if you found this helpful. Thanks, and good Luck!
SOURCE: How do I replace the
Replacement of the sand is easy but there are a couple of things you want to do first.
Make sure you have a good shop-vac, get gloves, and purchase the proper sand.
This sand filter calls for #20 silica filter sand. (this will be available online, at your pool store, or at any water treatment facility).
Here is the link for this filters manual, and for the brochure (which has good pictures)
http://www.waterco.com.au/CMS/uploads/brochures/ZZB0512_Thermoplastic.pdf
http://www.waterco.com.au/CMS/uploads/Manuals/Sand_manual_829006.pdf
The manual has step by step instructions on filling and starting the filter.
The only part it doesnt tell you about is how to empty the old filter media.
To start this:
1. turn off circulation pump
2. Bleed any pressure or vacuum from the system using the bleeder valve, or just rotate the multi-port valve.
3. Open the drain valve at the bottom of the filter if there is one (some dont have one)
4. remove the collar between the multiport valve, and the tank. (this should be 2 phillips head screws)
5.Remove the multi-port valve.
you now have access to the sand.
6. Remove sand by whatever means (either a scoop or a good shop-vac with a thick hose)
be sure to be carefull once you get 2/3 of the way down the inside of the tank. There are LATERALS down there that are most likely brittle from chlorine.
Once sand is removed check and clean the laterals at the bottom of the tank.
Clean and flush the filter body and follow the directions in the manual to fill and start-up the filter.
If this helped, please vote positively for me.
