Dryers Logo
Debbie Smith Posted on Nov 25, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My dryer will not turn on. after the last use it was extremely hot when i put the last load into the drum.The setting I used last was refresh model#dv410aew/xaa
Dennis Boxerman
Level 3:
  • Dryers Master 1,306 Answers
  • Posted on Nov 27, 2018
Dennis Boxerman
Dryers Master
Level 3:
Answers
1306
Questions
Helped
646267
Points
2787
Https://www.repairclinic.com/RepairHelp/Dryer-Repair/8-160--ZHY0MTBhZXcveGFh/Samsung-Dryer-Troubleshooting
Go to this web site and check out the trouble shooting guide. This is the first step to find the easy stuff. Let me know if I can help any more.
Chris Huff
Level 3:
Top Expert:
  • Dryers Master 6,289 Answers
Chris Huff
Dryers Master
Level 3:
Top Expert:
Answers
6289
Questions
Helped
2017741
Points
74913
Probably blew an internal fuse. May be caused by venting stopped up b
5 Related Answers
Anonymous
  • 146 Answers
  • Posted on Nov 01, 2007
SOURCE: tricity Bendix WDR1240W Condenser dryer problem
Check the fan that is supposed to blow the hot air into the drum. It may be seized or jammed. It should be situated on the top of the outer drum. You will need to remove the top cover from the machine and identify the blower fan.
Anonymous
  • 706 Answers
  • Posted on Nov 25, 2008
SOURCE: when the dryer gets hot it turns off, the dryer does dry
Here is a link for an exploded view of your dryer
http://www.pcappliancerepair.com/model-display.php
You may have a bad thermal limiter item # 1236 and your thermal safety switch is cutting in to disable power to your heater before it causes a fire. You may have a bad power resistor item # 1114 as well. Difficult to say which component is defective without being able to take measurements.. Hope this gets you headed in the right direction. Please remove or disable power before attempting to trouble shoot ( if you are doing this yourself)
Regards,
Rick
Anonymous
  • 44 Answers
  • Posted on Mar 17, 2010
SOURCE: whirlpool Electric dryer
If the heating element is getting very hot that means there is no air flow across it. If the drum doesn't turn then the blower is not turning causing the element to get very hot. Could be drum belt, drum rollers, or motor.
pantherprodu
  • 34 Answers
  • Posted on Mar 25, 2010
SOURCE: dryer modle Tc7102w/t5c7102s was working ok but drum won't rotate
Theres two things to look at, the brushes on the motor, replaceable and cheap, if they are are healthy then there is one or sometimes two large capacitors, these give the motor the ooomf to get it rotating, these fail which is a common problem with washing machines and dryers, again about £5= on ebay.
Anonymous
  • 3 Answers
  • Posted on Dec 01, 2010
SOURCE: I have a samsung dryer
This photo is from a Samsung DV409AEW, but I assume they are quite likely the same. I also turned the drum (clockwise, which is the wrong way) and the same thing happened. The thud in my case was the spring that holds the tension pulley arm in place falling to the bottom of the dryer. If your situation is the same, spinning the drum caused the belt to come off of the idler pulley and the tension spring fell off. It seems to happen frequently based on web searches.
Again, assuming the DV409Axx is the same, you can get at it from behind. There should be 3 screws (2 on the top and 1 on the bottom) of the plate that holds the vent pipe output assembly. That assembly can then be removed. There will be a vent pipe extension that comes out with the assembly.
Once inside, see if the spring is off, and if so re-attach it per the photo below. It is counter-intuitive that the spring pulls the arm down, rather than to the left. Hopefully this will be your issue.
Putting the pipe extension and outlet assembly back in can take a bit of fiddling... but if you lay on the floor, you can actually shine a flashlight in the crack to see what you're doing.
Hope this helps!
I want to know how hot my dryer gets. I do not have temp. controls on my model
Good Morning Tabitha,
I see that you are looking to see how hot your Frigidaire dryer, model# FER311FS, actually gets, due to you not having temperature controls on your particular model. Being that you have just the timed dry cycle, it provides up to 100 minutes of drying time at high heat for regular and permanent press items. When drying permanent press items, turn the cycle selector to 40-50 minutes. This is the average time needed to dry most loads of permanent press items. The load tumbles without heat during the last 10 minutes of the Timed Dry cycle. Use this setting to refresh clothing, pillows or blankets or to dust draperies. Heat-sensitive items such as plastics, foam rubber or similarly textured rubber-like materials or items containing feathers or down should be dried only with this setting. Hope this is helpful.
-Best Regards-
Kenmore Dryer won't turn on
Hi...
This are the tipe on how to Troubleshot dryer follow the steps below
IF the dryer is noisy
Level the dryer
Check the drum belt
Check the drum support rollers
Check the idler pulley
Check the glides
Check drum bearings
Check the blower
Check the baffles
If the dryer tumbles, but there is no heat
Check for proper air flow
Test the safety fuse
Test the thermostats
Test the centrifugal switch
Test the timer motor
Test the heating element
Good luck !!!!
Regards
PCmania
Ive got a hotpoint electric dryer that intermitantly blows hot air..in other words sometimes it wroks while other times dosent blow that much needed hot air to dry clothes..ive tried different things like...
Sounds like the drum is not turning under heavy load.this is a common problem with dryers but usually easily remedied if a competent diyer. first check the theory by putting in big load and see if drum turns. if not then replacing capacator should cure it.
Nov 06, 2008 • Dryers
Overheating and Won't Start
Does your dryer run at all? If the drum turns, but the dryer does not heat, click on the follwing link for advice:
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
Now, if your dryer does not run at all, you can use this link for more thorough information:
http://www.fixya.com/support/r385301-thorough_dryer_advice
I'm sure you've already made sure the dryer vents are clean, but if your dryer is running extremely hot like you mentioned, it usually means there is insufficient air flow. If you have ensured all the external duct work is clear, you may still have a clog INSIDE the dryer. In addition, if you are in the habit of pushing the dryer all the way up against the wall, you may be crushing the dryer vent hose to the point where it cannot push air. I mention most of this in these write ups. Please take the time to read through the information. If you have any questions, need help in diagnosing the problem, or assistance in locating parts, please let me know. I hope this helps you.
Older maytag dryer
2 things there first is noise the support rollers that old drum up and the pulley 4 the belt tightner needs replaced the dryng time as long as the dryer gitting hot is the vent going from dryer to outside pluged up
Feb 28, 2008 • Dryers
Tricity Bendix WDR1240W Condenser dryer problem
Clothes not drying
A couple of possibilities to check. First, is the lint trap empty? If so, then the symptoms point to hot air bypassing the drum. Look for broken or misaligned plastic ducting inside the dryer itself. Check the exhaust air for moisture, as that is a better indicator than temperature. Don't forget that towels hold an enormous amount of water, & can be extremely long in drying, especially if not spun enough.
Top Dryers Experts
john h
