Question about AEG Dishwashers
How do you replace a thermostat to AEG Favorite dishwasher 50870M
2 Suggested Answers
6ya staff
SOURCE:
joe_lishman
Joe Lishman
  • 192 Answers
SOURCE: AEG Favorite Compact 525 Dishwasher. The pump runs continuously
This is caused by the Anti-Flood device at the base of the machiene being activated. This device detects water leaks and is a polystireene float / micro switch that puts the machiene in pump out mode only. You need to determine where the leak comes from (pipe or perforated hose pin hole or pipe clamp etc.) If you tilt the washer and some water comes out from the bottom it is a clear indication that there is a small leak.
Posted on Jan 19, 2010
Aeg dishwasher dont worm the water
Could be:
- heating element
- thermostat or NTC sensor
- wiring
- electronic or timer
Dado
Jul 05, 2014 | AEG 24 in. Favorit 3A Free-standing...
AEG OKO FAVORITE 4070 - AFter not using for a week dishwasher is flashing dry & end together, will not switch off unless turn it off at the power point, there is no water left in the machine.
If the END or DRYING indicator on the programme progress display is flashing, you can probably rectify the fault yourself.
After rectifying an END or DRYING fault, press the button for the wash programme that has been started.
The wash programme continues. If the fault is displayed again, than check water leakage in the battom of dishwasher.
Malfunction: END and DRYING on the programme progress display are flashing simultaneously.
Possible causes: The leak prevention system has been triggered.
Remedy: Try to find and repair water leakage otherwise close the tap and call customer service.
Dado
Mar 16, 2014 | AEG 24 in. Favorit 60870M Free-standing...
AEG Favorite Compact 525 Dishwasher. The pump runs continuously even when the on/off button is pressed. any ideas
Mar 10, 2009 | AEG 24 in. Favorit 40850 Free-standing...
AEG Favorite Compact 525. The pump runs continuously even when the on/off button is pressed. Tho only way to stop it is to turn the power off at the socket/plug. any ideas
This seems like the anti flood system (polystireen float / micro switch) at the base of the washer is triggered,\. This puts the washer in pump out mode and stops inlet of water via the inlet solinoid. Dry the water on the base and then check for any water leaks. (pipe leak)
Aeg dischwaher model oko favorite
Nov 15, 2008 | AEG 18 in. Favorit 64800 Free-standing...
Drain pump keeps running AEG oko favorit
Aug 29, 2008 | AEG Favorit 50500 Built-in Dishwasher
AEG dishwasher not heating
Had simlar problem. It was the Program module. If yo open the program module you may see a burn track. Resoldering also ddid teh thrick
Aug 19, 2007 | AEG 23 in. Favorit 86070Vi Built-In...
Dishwashers Logo
Top AEG Dishwashers Experts
Paul Carew
Mike
Mark Brooker
Level 1 Expert
Are you an AEG Dishwasher Expert? Answer questions, earn points and help others
