SOURCE: Bosch Dishwasher SHV4303UC - Does not drain.
Try looking for slithers of glass etc under the impeller. Remove the sump covers (filters) and look into the bottom. There will probably be a small cover held down by a screw. Under this is the impeller. Roll up a hand towel into a cigarette shape and slide this under the impeller - that should clear anything out.
SOURCE: Kenmore Elite wont power on
Door switch. If the washer thinks the door is open, it won't run.
SOURCE: Bosch Dishwasher will not power on
I have a bosch dishwasher model 2046. When you try start the cycle you hear the timer inside start to activate but the cycle doesn't start. The light in the start switch does not come on as well but I think it may be burned out. We have checked the breaker and I seems to have power.
Gerald
SOURCE: looks like program in electronic dishwasher has
im a old bosch tech . the problem is the module or the drain pump is stuck. if this helps please give me a 4 thumbs up post thanks.
SOURCE: Bosch Dishwasher (SHE44C05UC) won't turn on
Just had the same problem, same model. Found the wiring below the front cover fried. So now I'm checking to see if anyone else had this happen.
START/RESET status indicator light flashing
You have pressed the indicator light flashing START/RESET pad while the START/RESET dishwasher is running. This will cancel the cycle. The light will stop flashing after the dishwasher drains (about 90 seconds).
• Press the pad once to start the dishwasher. Press the pad a second time when the dishwasher is running only if you wish to cancel the cycle.
Power to the dishwasher was turned off while a cycle was running and power has just been restored to the dishwasher. The blinking lights indicate that the dishwasher is draining the potential water inside.
• The light will stop flashing after the dishwasher drains. A new cycle will start automatically.
Good luck
