Question about American Standard Home
American standard hands free toilet battery pack doesn't work
Seems like there is no more electrical circuit. Can still push button to flush but can't waive my hand and have flush even with new battery's
  • 10,543 Answers
More likely the sensor has malfunctioned.
Posted on Nov 24, 2018
6ya staff
SOURCE:
ve3wtj
David Friesen
  • 147 Answers
SOURCE: 2004 Civic Drivers door lock
The driver's side door lock button is designed not to lock from the inside unless the handle is pulled, or the power switch is used. This serves as a reminder to not lock your keys inside.
If you are inside, and push down on the button (not the switch) hard enough to lock it, you've probably damaged it.
Posted on Sep 17, 2008
Anonymous
  • 4 Answers
SOURCE: the sound from my radio
taking out the fuses and putting them back in again works but before you put the fuses back on clean the end of the fuses with a bit of steel wool and take the oxidation residue off and put them back in or just replace fuse number 7,72 and 73 and it should work perfectly fine.
Posted on May 14, 2009
ryanamontos
Ryan Amontos
  • 60 Answers
SOURCE: ford focus 2007, hands free system
Some Bluetooth devices got different pin code or pass code, but most Bluetooth devices uses 0000 and 1234.
Posted on Jun 09, 2009
m111den
m111den
  • 94 Answers
SOURCE: Vodafone are having probelms fitting a hands free
hi
normally nissan use a 1 or 2 plug loom, as long as noboby has butchered it to fit aftermarket radio, shouldny have a problem getting a loom. try daltac.co.uk.
hope this helps
Posted on Mar 03, 2010
l19f9
SOURCE: my keyless remote doesn't work
before you spend too much money...try this.
On the inside of the keyless remotes, there are rubber buttons, those rubbers buttons are brushed with metal of some sort so that it reacts with the motherboard, when the remotes get older this metal wears off...so try this, it worked for me...
I superglued foil paper to the back of the button (the parts that touches the motherboard when pressed) and replaced the batteries... it worked like a charm, I used an awl and a hammer to make perfectly round piece of foil and just glued it onto the back of the button... i'd try this first before spending any real money.
Posted on Mar 17, 2011
Is there a way to change the toilet from front flush to top flush to accommodate the button on the top of the unit in the tank?
So did the top not come with the tank itself, is it a replacement? Or is it a tank where you can choose top or front flushing?
In my experience the mechanism for top flush is more complicated than front flush which just lifts the flapper. Take the top off and look. See if there is a link that can be taken from the front and clipped to the top. you state is has a 'self contained unit', so it doesn't sound like a standard lifting flapper, so you may well be able to choose.
Jan 01, 2016 | Home
My brand new toilet american standard round front model cadet 3 tank not fill water
If you verify that the water supply to the toilet is turned on, push down the float on the flush valve. Water should start flowing. If it doesn't, something (such as debris) may be blocking the valve and preventing filling. The new valve could be defective - permanently closed.
Jan 11, 2013 | American Standard Cadet 3 Right Height...
American standard toilet doesnt always flush, water swirls around
There is a clog in the line. A plunger usually solves this problem, but you have to use a toilet plunger. Your local hardware store will give you the right tool ($13). If the plunger doesn't work, you need a toilet auger (also called a closet auger), which you can buy for less than $20.
Apr 26, 2012 | American Standard Home
My toilet doesn't flush every time I flush it! It only flush If I pour a little more water into toilet bowl while water coming down toilet bowl! I've checked water level in tank and it was full...
I think the problem with your toilet bowl is in the tank fitting of it..you better check if the fittings are proprerly working..You also check the flapper and also the fillvalve.
If it is not good already you can replace it by buying the tank fittings at the hardware store..And you better also be check it to your plumber for the second thought..
Jun 17, 2011 | American Standard Home
Toilet flushing problem! I purchased an American Standard Cadet 3 High HET toilet (1.28 gallon). When I flush the toilet, the flap will not stay up to allow the water to drain from the tank. When handle is...
The siphon mechanism works on a vacuum principle. If there is the slightest damage to the siphon membrane you will experience the problem you describe. A new siphon is required.
Dec 31, 2009 | American Standard Cadet 3 Right Height...
My toilet does not flush properly. It seems to
You might check under the rim of the toilet, there are about 12 little holes that when you flush water comes out to start the most important part of the flush. The swrill, with out it hard to flush. Talk a piece of wire hanger ( I know "NO WIRE HANGERS") and use it to push up into the holes. Hard water deposits sometimes build up there.
Sep 27, 2009 | Home
Need to replace working parts , push button , one piece toilet
Here is a link to a site with a ton of replacement parts for amstan toilets.
Without model numbers etc. its hard to know exactly what parts you need but you should be able to look at the pictures on the site and order the right parts...
http://www.plumbingsupply.com/amstan.html
HOpe that helps...
Jan 27, 2009 | American Standard - Lavatory Faucet -...
I have the American Standard Champion 4 toilet. Water is leaking from the tank to the bowl causing the toilet to refill. I've replaced the flapper and cleaned the surface the flapper contact. Nothing seems to work.
Nov 09, 2008 | American Standard 2002.014 - Champion4...
Home Logo
85 people viewed this question
Top American Standard Home Experts
US Parts Center
US Parts Center
Mike
john h
Are you an American Standard Home Expert? Answer questions, earn points and help others
