SOURCE: GE Wall Oven JKP70 Locks and reads F9
From all the information I could gather on this issue, including speaking with a GE tech I decided to call in a repair person.
SOURCE: Whirlpool wall oven stopped working after power outage
Ouch...sounds like the control module is blown. Thats the electronic timer. I've known this happen on several occasions. Bad luck!
SOURCE: whirlpool oven not heating up, though grill, fan and light still
Hi.
If fan in oven is working o/k, then the prob is most likely the oven element is faulty, and needs to be replaced.
Please rate my solution.
Thanks.
SOURCE: I tried to "clean" the oven and only got a F9
The F9 error code indicates a problem with the oven door lock assembly. The door lock assembly will need to be checked and replaced if defective. If the door lock assembly is okay, then the electronic oven control board will need to be replaced.
