I would like to order the replacement if I can get an answer.
Is is the main ? or the Power?
Felix C
SOURCE: Replacing the main Board to eliminate howling noise
I have had a number of these complaints and I have always repaired it by replacing the evap fan motor. It is a much cheaper part, however, its way more difficult to install than the main board. Yes many other techs say it can be resolved with a new main board and yes it is just a matter of plugging the wires in. I would be very interested to see if indeed it does resolve the howling. It will come with an instruction sheet that says you will need to cut a wire from one of the harnesses. Just disregard this if indeed your model is the one that you selected and is fairly new. (PSS26msr). If you would like to take advantage of my employee discount I can send you the part for $100 plus $20 shipping. Just let me know.
SOURCE: How to replace a power adapter on a Dell E171FP LCD
this is a monitor you shuld not open this as it has very high power running thru it. get dell onto it
SOURCE: Main Power Board
The power supply board can be changed without any knowledge of repair but there are sometimes adjustments necessary if the picture is not normal. Many times it is fine. There a 4-5 voltage adjustments that would take some knowledge and a meter to accomplish. You need to hope it was diagnosed properly first. If it is completely dead the p.s is a good possibility. If it clicks on then back off almost immediately it is not likely the power supply.
SOURCE: I have a dead E151FP monitor...need either a schematic or another damaged monitor
You can get repair instructions for the Dell E172/E151FP at ezinearticles.com and order transistors at AnBparts on ebay.
SOURCE: Power Problem with Zenith Z50PX2D
I had the same problem with same model TV a year back, they replaced some board (I was not there at home) as I had warranty and after a year same issue popped up again.. Can you please tell me what board replacement worked for you. I don't have warranty anymore.
