Sewing Machines Logo
M
Maria Fraser Posted on Nov 17, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I alter the top tension manually on the husqvarna Viking Sapphire 930 for free motion stitching. I want to create a whip stitch where the bottom thread comes up to the top of the work.
R.A. Ellis
Level 3:
  • Husqvarna Master 12,731 Answers
  • Posted on Nov 18, 2018
R.A. Ellis
Husqvarna Master
Level 3:
Answers
12731
Questions
Helped
2613428
Points
59176
Increasing the top tension (and possibly decreasing the bottom tension) will cause the top thread to pull the bobbin thread up.
5 Related Answers
Anonymous
  • Posted on Feb 12, 2008
SOURCE: how do I adjust the bottom thread tension?
some machines have a nob on the front loose is low numbers like 0 1 -2 most machines work well on number 3. If the nob is not on the front check and see if it is on the side.
Mimito7
Kelley Buchanan
  • 130 Answers
  • Posted on Apr 19, 2009
SOURCE: Top thread stitches correctly but bottom thread loops.
FYI---- Loops on the bottom-- problem is in the threading..
Loops on the top--- problem is with the bobbin.
jmgldsmth
Jim Goldsmith
  • 2005 Answers
  • Posted on Apr 29, 2009
SOURCE: singer 221-1 stitching is good on bottom but not on top
pucker is caused by too loose or, to tight adjustment of: the thread tensioners both the bobbin tensioner and, the needle tensioner need to be adjusted: to adjust the needle tensioner turn the side knob clockwise is tighter counterclockwise loosens; the bobbin tensioner is a tiny screw on the bobbin holder adjust both tensioners until your stich loops' both top and, bottom are tight but, the machine does not break the thread
deborahcha
  • 371 Answers
  • Posted on Sep 24, 2009
SOURCE: husqvarna viking, interlude 435...unable to solve tension problem
Sounds like the tension unit is at fault. First check the bobbin tension by removing the bobbin case. Use a half-full to 3/4 full bobbin. Be sure it is threaded through the bobbin case with thread hanging straight down with tension spring on top. Tie the stitch plate to the end of the thread. If the thread pulls the bobbin out, the bobbin tension is too loose. If it does not move when "jiggling" the bobbin, it is too tight (which is not likely based on your description). Small screw (through an open hole) on the side of the bobbin case adjusts the tension of the bobbin case. Left for loose and Right for tighter. Otherwise, contact local authorized Husqvarna Viking dealer for their assistance. You can find the closest dealer at the Husqvarna Viking website - http://www.husqvarnaviking.com/us Good luck.
deborahcha
  • 371 Answers
  • Posted on Feb 11, 2010
SOURCE: viking husqvarna classica 100, thread tension
I suspect you are correctly threading the machine but the timing of the needle and bobbin hook is off. When the threaded needle goes into the bobbin area, a pointed hook grabs the thread and loops it with the bobbin thread. Something is catching when the needle starts to come up that is not allowing the bobbin thread to be pulled back through the needle plate opening by the upper thread. With machine threaded and bobbin in place, have the bobbin area open if possible and watch the thread interaction when the needle goes down. To set the hook/needle timing, normally covers have to be removed. Suggest taking it to an authorized Husqvarna Viking dealer for service. You can find the nearest dealer by click on the "Dealer" link at http://www.husqvarnaviking.com
Good luck.
I have a Husqvarna Viking Optima 120 sewing machine. It was working fine, then out of the blue the bottom thread is bunching up?
Question edited for full 'make model (what it is)'.
Question moved to maker category.
You either have a threading issue, or a tension issue, or both issues. Read the Article and watch the videos.
By thread tension, we mean the amount of thread that can pass through the machine to create the stitch. The more thread in the stitch, then the looser the stitch. The less thread, then the tighter the stitch. Top thread tension is controlled by a dial on the machine's thread path.
Sep 11, 2018
Adjusting tension on sewing machine - Artisan Stitch
I need an electronic version for a Viking Sapphire 930 users manual and trouble shooting guide. Thank you
Husqvarna Viking has the manual for the Sapphire 930 on the product page: http://www.husqvarnaviking.com/en-US/Machines/SAPPHIRE-930 . The direct link to the User's Guide is http://www.husqvarnaviking.com/getattachment/Machines/SAPPHIRE-930/Sapphire930-manual-EN.pdf.aspx . The trouble-shooting section starts on page 51. For some issues, you may need to contact a service technician through a Husqvarna Viking dealer. Some parts are still available here: http://www.sewingpartsonline.com/viking-sapphire-930-parts.aspx .
I hope this helps.
1helpful
I can not remember how to set my Viking Designer 1 for free motion sewing
Drop the feed dogs and install a darning or free motion presser foot. Be sure to use a brand new needle. The stitch width should be set on zero. The stitch length really doesn't matter since you will be manipulating the material manually.
Then you will need to test on a scrap sandwich block made up of your fabric and batting to adjust the tension. Tension is appropriate when the upper and bobbin threads meet in the middle of the sandwich without any thread looping or pulling.
You may be able to find a manual by asking your local Viking dealer or search the internet for:
Make Model manual
Viking designer 1
Hi, Free motion quilting is done with your programmed quilting stitches, Lower the feed dogs using the small white dial on the front of the machine behind the accessory tray, pick from one of the quilting stitches. they do make a free motion quilting tool ( I think they call it a hoop), but it just sets on top the material and helps you guide your material thru the machine. Hope this helps
Remove thread message in husqvarna viking sapphire 870 quilt
I had this same problem, on my Designer Diamond. I blew it out with an air can and that didn't work, but then I decided to turn it off, then back on and start sewing a line in reverse. That seemed to fix it. My machine is working fine now.
Ordinary straight stitching
When you turn on a #1 Husqvarna Viking the machine defaults all the electronic settings to do a straight stitch at a 2.5mm stitch length, that equates to approximately 10 stitches per inch. The top tension dial sets itself automatically and the only other dial is on the left side of the machine. That dial sets the pressure on the foot that holds down the fabric. It's normal setting is 6.
4helpful
I just bought a used Husqvarna 2000 sl without a manual.
If you have on old Husqvarna 2000 from the 1970's, then the knobs are as follows:
Top front left: Pattern Selector
Top right: Stitch width
Lower: Stitch length and buttonhole (when turned to 0 and pulled out)
Extreme left: Upper tension
Side left: Presser foot pressure
Husqvarna viking, interlude 435...unable to solve tension problem
7helpful
2answers
Free motion quilting Viking Designer 1
I had the same dissatisfaction when I switched from the 1+ to the Designer 1. After some trials I am now happy. You need the springy free motion foot. Part #413 03 76-45. You take off the white shank and screw it on with the metal bar over the needle hook. In the set menu turn the SensorQ on, the free motion on, select stitch 1 from menu V and drop the feed dogs. It also makes a big difference to use the straight stitch throat plate which just has a small hole for the needle to go through. One other hint is that I often have to reduce my needle tension 3 or 4 steps. Hope it works for you.
3answers
Free Motion Sewing - Jams
The Designer 1 usually has a very nice free motion stitch using the V1 stitch. It should pull only slightly to the rear so that no bobbin thread shows while doing free motion embroidery. Upper tension may be increased for balanced stitch when stippling.
If your machine doesn't sew with the regular stitches with the teeth up, and it's properly threaded, the thread must be dragging on the bobbin case somewhere. First get the machine sewing a straight line, then try V1 again.
Top Husqvarna Sewing Machines Experts
ZJ Limited
ZJ Limited
Sean Wright
Sean Wright
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
