Lands Phones Logo
L
Linda Dishaw Posted on Nov 17, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Phone does not ring when calls come in - Lands Phones
Julian Wainwright
Level 2:
Sergeant:
  • Expert 205 Answers
  • Posted on Nov 17, 2018
Julian Wainwright
Expert
Level 2:
Sergeant:
Answers
205
Questions
0
Helped
180106
Points
614
If you have a button that looks like a speaker with a cross through it try pressing that, alternatively try turning up the ringer volume as it's currently set at 0.
Testimonial: "thank you for answering my question but it didn't work"
I can make calls but phone doe not ring
You said "it seems to ring once then stops." One possible cause of what you're describing is called a "Ring Trip." It is characterized when the button that flashes to indicate an incoming call changes to steady red (which would normally indicate the call is answered) although no one actually answered the call. If that occurs, then you have to test to see whether you can tell where the problem is coming from. If you unplug all the phones, you can then call in (from a cell phone or other phone that's not part of the system) and see if the incoming call rings unanswered, as it should when no phones are attached. If all rings in OK, plug just one phone in at a time and call in to see if any particular phone causes the problem. If one causes the ring trip, then disconnect that broken phone. If ringing still stops when no phones are attached, you'll have to disconnect the phones' connection wires (Station Wires) at the phone system box that plug into the "Station Ports" (label them before you unplug any!). Do not unplug the plugs for the wires that feed phone company lines into the phone system, the jacks are called CO line ports. With the "Station" wires unplugged, see if If all rings in OK by calling in from a cell phone or other phone that's not part of the system. If all rings in OK, plug just one station wire in at a time to see if one causes the problem. If one station wire causes the ring trip, then disconnect that troublesome wire and inspect its "system box jack" and its phone jack for water damage, carpet cleaning solvent, exterminator spray or any other corrosive liquid damage. Sometimes a staple through a wire where there's humidity can cause the problem. This process will find the offending wire, jack or phone that causes a "Ring Trip." There are many other possibilities, but the extremely limited description you've provided "it seems to ring once then stops." doesn't help me send you a better answer yet.
Phone does not ring
Time to get new phones. You incoming wires are not operating on the base of the phone. It is called the 'ring-side' or 'red' wire. Unless you know where the break is, you cannot fix it. because it happens on all the phones....it has to be broken in the base that serves them all. This isolation is furthered by the fact that a corded phone works fine on incoming calls, so it is not in the line to the building, broken on the ring side that is. Happy phone hunting!
blkqueentech
Panasonic number ring
Answering system settings
Number of rings before the unit answers a call.You can change the number of times the phone rings "Ring count"before the unit answers calls. You can select 2 to 7 rings, or "Toll saver".The default setting is "4 rings"."Toll saver": The unit's answering system answers at the end of the 2nd ring when new messages have been recorded, or at the end of the 5th ring when there are no new messages. If you call your phone from outside to listen to new messages (page 34), you know that there are no new messages when the phone rings for the 3rd time. You can then hang up without being charged for the call.
4helpful
2answers
Our incoming calls are not ringing?
wen i receive incoming calls there is no ring or message alert
14helpful
2answers
Phone won't ring with incoming calls
I just bought a new Uniden DECT 6.0 phone and had a similar problem. It wouldn't ring when plugged into my Linksys voip router, but my old 5.8 GHz did ring. It would get a dialtone and make calls, but when called via an outside line, it would appear as if it was ringing. If I picked up during this "silent ring," it would answer and take the call. It wasn't a ringer volume issue. I called tech support, they said on the main headset, unplug the battery, then unplug power from the base, then unplug the phone cord from the base. Wait 15-30s. Plug the phone cord, then power, then reinstall the battery. Press the End button on the phone. Put the phone on the base for 15-30s. Pick up the phone. Press and hold the Find button on the base. Do this Find thing 3 times. Put the phone back on the base. Wait 10-15 minutes. Then try calling it to see if it rings. Worked for me, finally got it to ring before I decided to return it.
1helpful
2answers
Need to have a Mitel SX 50 Phone System ring on cordless phones
You can switch to "night" mode on the console and the incoming calls should ring on the cordless. try it.
2helpful
My phone is not ringing on incoming calls
did u try removing the battery and reinserting after 2 min..
and if already tried,
then try dialing from oter phones, or check the assign tone in ur phone contact from which ur testing to be assigned with some ring tone...
How do I change ringing to all handsets at the same time
SET ring to standard and not musical or distinctive ring. SINCE I am in India WHAT kind of line you are using isnot known.thereis setting on FAX to detect fax tone. Switch phone Fax switch to AUTO.
Missing calls
I had this problem once and on my phone I would get one ring and then it would stop. Checking the phone I saw I missed a call. I live in the mountains of Puerto Rico and I believe what is happen is the network plays the rings for the caller but the phone isn't doesn't get the signal or start ringing until 3 or 4 rings later. In other words the caller has already heard 4 or 5 rings and has given up. While you have heard only one ring and when you got to the phone you already missed the call. I told my friends to let it rings more then 5 times before giving up and that worked.
Top Lands Phones Experts
k24674
Are you a Lands Phone Expert? Answer questions, earn points and help others
