Question about Bosch Washing Machines
My washer bosch maxx wfl 249y 6 kg stop between the rinses or into the rinses. I open the door and turn the drum cloce the door and start again
    Top Expert:
  • Bosch Master
  • 64,733 Answers
SOUNDS LIKE YOU MIGHT NEED A NEW MOTOR THEY DO DEVELOP DEAD SPOTS
Posted on Nov 16, 2018
6ya staff
SOURCE:
Anonymous
SOURCE: Bosch Maxx WFL 2850 - the drum will not turn around
Check the electronic board for a short.
Posted on May 31, 2008
Anonymous
SOURCE: BOSCH MAXX WFL 1650 front load problem please help
i need translate to hebrew i dont know how to use it
Posted on Jul 19, 2008
douglas smith
  • 1462 Answers
SOURCE: Bosch Maxx WFL 2060
connect at random. put on a rinse cycle. if cold water comes in then pipes are correct. if hot water comes in then pipes are wrong way round and just swap them
Posted on Sep 13, 2008
AZEBO .
  • 228 Answers
SOURCE: The water does not cutoff during rinse cycles
pressure chamber blocked with soap depists scale etc will need removing for service and cleaning partial strip down required.
Posted on Feb 17, 2010
roos130842
SOURCE: Bosch Maxx 5 Washing machine will not wash, drum does not spin.
maxx5, error F63
Posted on Dec 14, 2010
I have a Bosch Maxx WFL 1662 washing machine. It does not stop washing and go over to the rinses sickle.Where do i start looking for the problem?
Hi Eric, There's two links below... 1st link is Bosch Washing Machine Error Fault Codes and the 2nd link is worth reading, The master reset is only part of the trouble shooting, I hope these help.
To perform the Master Reset, carefully unplug the washing machine from the power outlet and leave it unplugged for one minute. After one minute is up, plug the washer cord back into the wall. Next, open and close the door of the washing machine 6 times within 12 seconds to send a "reset" signal to all the components. (This is a common fix that many appliance repair mechanics use - it works on about 50% of all washing machines.) Once the reset has been completed set the washer to do a small load with no clothes in the washer. See if the washer goes through with the cycle as normal. If the washer performs correctly, then it has been reset and is fixed. If not refer to more troubleshooting techniques and causes of problems below.
How To Fix Washing Machine That Is Not Spinning or Draining
Apr 02, 2016 | Bosch Washing Machines
The water does not cutoff during rinse cycles on the rinse plus and normal wash programmes on my Bosch Maxx WFL 2060 but works fine on quick wash programme
Feb 14, 2010 | Bosch Axxis WFL 2060 Front Load Washer
Washes until before rinsing and stops.
I think the problem was a bad waterfill value. removethe water from the base
RINSE/DRY = Water filling fault (over or under filling)
regards
balisonu79
Jan 04, 2010 | Bosch Washing Machines
The drum stopped turnig and there seewms to be no life in the motor on our BOSCH Maxx WFL 2060 does any one have any idears. Thanks
you need to test the motor to see if voltage is getting to it.. if yes change brushes or motor complete...01179512835
Dec 30, 2009 | Bosch Axxis WFL 2060 Front Load Washer
Bosch Maxx WFL 2061 motor starts running and then stops
Hi ! I have problem with my Bosch Washer wfl 2061 .. It was running till stoped to
realease drain water out... But no drain water come out.. I have checked drain water host... Nothing thaere.. Water was still in the drum Tank... Whoever knows this problem , please kindly suggest or help me to do something.. Thanks.. Peace pkurdnirund@hotmail.com , peacepattaya@gmail.com
Nov 28, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Troubleshooting
I had that. closed the door properly and it went away
Sep 23, 2008 | Bosch Classixx WFL 2066 Front Load Washer
Bosch Maxx WFL 2060
Sep 13, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Bosch Maxx WFL 2260
My drum stop, then I put in new carbon brushes. It works very good in 2mouth, now it stop again. Wht can be problem?
Jan 17, 2008 | Washing Machines
"Check Water Tap" error
rinse valve possibly open circuit or external water pressure low
Feb 08, 2007 | Bosch Axxis WFL 2060 Front Load Washer
Washing Machines Logo
56 people viewed this question
Top Bosch Washing Machines Experts
Marvin
Marvin
jimorris77
Dw Wooten
Dw Wooten
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
