SOURCE: 1 year old hayward h1001d pool heater clicking
see this link ....
http://www.fixya.com/support/t1078177-hayward_pool_heater_h_series
SOURCE: pool pump noisy
maybe plugged or restricted with something. try cleaning it and see if that will help.
Actually, the clicking is likely causing the shaking. Inside the manifold of a H100 is a stainless steel diverter plate that send some of the passing water into the heat exchanger and lets the rest past and back to the pool. When it breaks, you will hear a 'clicking' noise at it rattles in the water path. When it breaks, the flow to the heat exchanger is intermittent and you will begin to boil the water, causing the shaking. This situation is dangerous, especially without a pressure relief in the heater or pipe. As long as your water chemistry is sound, Hayward will usually cover this under warranty even if the unit is over a year old. Contact them to get a factory authorized repair rep out at: http://www.haywardnet.com/locator/
SOURCE: in-g pool loss of pressure and bubbles from return line any ideas
If you notice bubbles in the water returning into the pool from the eyeball/discharge, or water in the strainer basket is visibly swirling (bubbles visible) odds are you need you replace the o-ring on the lid of the strainer basket in the front of the pump. This basket may also be clogged with debris, which also effect pressure. Could also be a cracked or warped strainer lid. Should be easy to see when you remove to check o-ring. Once you remove the strainer o-ring make sure you lube it with a good silcone based lube.
SOURCE: I have a hayward super pump. Model K48M2N111 The
NO FUSE, YOU CAN USE A VOLT METER AND CHECK THE 2 SCREWS WHERE THE POWER HOOKS UP ON THE BACK OF THE MOTOR , THIS SHOULD BE A 230 VOLT SYSTEM . IF NO POWER AT THE MOTOR THEN CHECK IT AT THE TIMER AND THEN THE BREAKER.. GOT 230 OR SO ? IT'S A BAD MOTOR .. LOOK AND SEE IF YOU HAVE A PUMP REPAIR SHOP IN YOUR AREA THAT DOES FREE TESTING , YOU WILL NEED TO BRING IN THE MOTOR .. FOR FREE TESTING REMEMBER TO VOTE FOR YOUR FAVORITE FIXIT GUY ! THANKS JAY
